Unify Automounter Maps Using LDAP in Raspberry Pi
Published
Introduction: Unify Automounter Maps Using LDAP in Raspberry Pi
About: Systems Administrator and Software Programmer.
Introduction
Besides the ability to store password and user accounts, LDAP can also store automounter maps. This makes maintenance of automounter map fast and easy.
Scope
This instructable will show how to:
  • Install automount-LDAP related files
  • Install automount schema in OpenLDAP
  • Create automount maps in LDIF format
  • Add the automount maps to LDAP database
  • Configure autofs and automount to access automount maps
  • Test
This instructable will show how to configure encryption and TLS
Prerequisite
Complete the "Unify User Passwords and Home Directories Across More Than One Raspberry Pi Devices" instructable before starting on this instructable.
Solution
We need to have at least 2 Raspberry Pi runnung Raspbian OS. For simplicity, I will call the 2 Raspberry Pi devices as Rpi1 and Rpi2:
Rpi1 will have:
  • LDAP server with user account database and automounter maps
  • NFSv4 server sharing home directories
Rpi2 will have:
  • Automounter mount users' home directory located in Rpi1's NFSv4 server but now it looks up autofs maps in LDAP server of Rpi1
  • LDAP authentication using Rpi1's LDAP server
Environment
The following are data of the 2 Raspberry Pi:
Distributor ID: Debian
Description: Debian GNU/Linux 7.8 (wheezy)
Release: 7.8
Codename: wheezy
Linux rpipro.example.com 3.18.9+ #767 PREEMPT Sat Mar 7 21:41:13 GMT 2015 armv6l GNU/Linux
References
/usr/share/doc/autofs-ldap/examples
https://help.ubuntu.com/community/AutofsLDAP
https://access.redhat.com/documentation/en-US/Red_...
Step 1: Install Automounter Schema
Open terminal emulator in Rpi1
Install autofs LDAP related software and schema:
sudo apt-get update
<br>sudo apt-get install autofs-ldap
Step 2: Configure OpenLDAP Server to Load the Autofs Schema
Check if LDAP is configured with autofs schema:
sudo ldapsearch -Q -LLL -Y EXTERNAL -H ldapi:/// -b cn=schema,cn=config dn | grep autofs
If output is empty, then LDAP is NOT configured with autofs schema. It is assumed the LDAP server is not configured with autofs schema from here on.
Locate the autofs schema:
ls -l /etc/ldap/schema/autofs.schema
Convert autofs.schema into ldif format:
cd ~
mkdir ldap_wip
cd ~/ldap_wip
Create the conversion configuration file schema_convert.conf containing the following lines:
vi ~/ldap_wip/schema_convert.conf
<br>include /etc/ldap/schema/core.schema<br>include /etc/ldap/schema/collective.schema <br>include /etc/ldap/schema/corba.schema <br>include /etc/ldap/schema/cosine.schema <br>include /etc/ldap/schema/duaconf.schema <br>include /etc/ldap/schema/dyngroup.schema <br>include /etc/ldap/schema/inetorgperson.schema <br>include /etc/ldap/schema/java.schema <br>include /etc/ldap/schema/misc.schema <br>include /etc/ldap/schema/nis.schema <br>include /etc/ldap/schema/openldap.schema <br>include /etc/ldap/schema/ppolicy.schema <br>include /etc/ldap/schema/pmi.schema <br>include /etc/ldap/schema/autofs.schema
Create the output directory ldif_output:
mkdir ~/ldap_wip/ldif_output
Determine the index of the schema:
slapcat -f schema_convert.conf -F ldif_output -n 0 | grep autofs,cn=schema<br><br>Output: <br>dn: cn={13}autofs,cn=schema,cn=config
Use slapcat to perform the conversion:
slapcat -f schema_convert.conf -F ldif_output -n0 -H ldap:///cn={13}autofs,cn=schema,cn=config -l cn=autofs.ldif
The converted schema is now in cn=autofs.ldif file
Edit cn=autofs.ldif
vi ~/ldap_wip/cn\=autofs.ldif
<br>Change:
<br>To:
<br>dn: cn=autofs
<br>Change:
<br>cn: {13}autofs
<br>To:
cn: autofs
<br>Remove the following lines:
<br>structuralObjectClass: olcSchemaConfig
<br>entryUUID: adafd1aa-61b8-1034-8caa-a9ffd93db1c1
<br>creatorsName: cn=config
<br>createTimestamp: 20150318124727Z
<br>entryCSN: 20150318124727.871648Z#000000#000#000000
<br>modifiersName: cn=config
<br>modifyTimestamp: 20150318124727Z
Save the file
use ldapadd to add the new schema to the slapd-config DIT:
sudo ldapadd -Q -Y EXTERNAL -H ldapi:/// -f ~/ldap_wip/cn\=autofs.ldif
Confirm autofs schema is one of the currently loaded schemas:
<br>Output:
<br>dn: cn=schema,cn=config
<br>dn: cn={0}core,cn=schema,cn=config
<br>dn: cn={1}cosine,cn=schema,cn=config
<br>dn: cn={2}nis,cn=schema,cn=config
<br>dn: cn={3}inetorgperson,cn=schema,cn=config
<br>dn: cn={4}autofs,cn=schema,cn=config
Step 3: Add Automounter Map to OpenLDAP
Download the ldif into the I uploaded into ~/ldap_wip directory and rename it to automounttree.ldif
Read the data entries in the ldif and note that it is a automounter map written is ldif format
Add the entries to LDAP:
sudo ldapadd -D cn=admin,dc=example,dc=com -W -f ~/ldap_wip/automounttree.ldif
Step 4: Configure Automounter to Access OpenLDAP
Open terminal emulator in Rpi2
Make backup:
sudo cp /etc/default/autofs /etc/default/autofs.pristine
Change /etc/default/autofs:
sudo vi /etc/default/autofs
Change:
MASTER_MAP_NAME="/etc/auto.master"
To:
MASTER_MAP_NAME="ldap://192.168.0.6/ou=auto.master,ou=automount,ou=etc,dc=example,dc=com"
Change:
#LOGGING="none"
To:
LOGGING="verbose" #Change it back to "none" when you get successful results
Change:
#LDAP_URI=""
To:
LDAP_URI="ldap://192.168.x.x" # This is the IP address of your LDAP machine/device or Rpi1
Change:
#SEARCH_BASE=""
To:
SEARCH_BASE="ou=automount,ou=etc,dc=example,dc=com"
Uncomment the following lines:
MAP_OBJECT_CLASS="automountMap"
ENTRY_OBJECT_CLASS="automount"
MAP_ATTRIBUTE="ou"
ENTRY_ATTRIBUTE="cn"
VALUE_ATTRIBUTE="automountInformation"
Step 5: Configure Autofs_ldap_auth.conf
This instructable will NOT have automounter do TLS and authentication
vi /etc/autofs_ldap_auth.conf
autofs_ldap_sasl_conf
usetls="no"
tlsrequired="no"
authrequired="no"
Step 6: Configure Nsswitch With Automount
Make backup:
sudo cp /etc/nsswitch.conf /etc/nsswitch.conf.pristine
Add automount entry:
sudo vi /etc/nsswitch.conf
Add the following:
automount: files ldap
Save the file.
Step 7: Configure Ldap.conf
sudo vi /etc/ldap/ldap.conf
BASE dc=example,dc=com
URI ldap://192.168.x.x # LDAP IP address
Step 8: Initial Test
Open 2 terminal emulator windows in Rpi2
In first window, monitor syslog:
tail -f /var/log/syslog
In second window, we can disable file-based auto.master during testing to make sure automounter is reading from LDAP server:
sudo mv /etc/auto.master /etc/auto.master.disable
In second window, restart the service
sudo service autofs stop
sudo service autofs start
The output of syslog should not indicate any failure to lookup any maps:
Mar 19 09:19:38 raspberrypi automount[4880]: Starting automounter version 5.0.7, master map ldap://192.168.0.6/ou=auto.master,ou=automount,ou=etc,dc=example,dc=com
Mar 19 09:19:38 raspberrypi automount[4880]: using kernel protocol version 5.02
Mar 19 09:19:38 raspberrypi automount[4880]: mounted indirect on /home/ldap with timeout 60, freq 15 seconds
Re-enable the auto.master file (Although automounter is not going to use it):
sudo mv /etc/auto.master.disable /etc/auto.master
Step 9: Functional Test
Reboot Rpi2:
sudo reboot
Enter John's credential in login screen:
user: john
password: johnldap
Rpi2 will take between 1 to 2 minutes to authenticate and automount the home directory
If the desktop is loaded, then the LDAP authentication is successful.
Open terminal emulator in Rpi2:
pwd
If output of above command shows /home/ldap/john, then automounter is using maps stored in LDAP.
    • Creative Misuse Contest
    • Oil Contest
      Oil Contest
    • Clocks Contest
      Clocks Contest
