foils self adjust to maximize power.
It rotates vertically instead of horizontally. (also known as a VAWT) . There are many different designs on the INTERNET where the foils adjust, but this is my own unique design. What makes this design nice is that it is easily scaled up or down in size, and there is no welding required.
Most of the parts can come off with a screw driver so you could really play with the sizes.
Most of the tools used are standard tools.
There are two videos that I have made in association to this instructable, one shows the mechanics of how it works, the other is a short video of the working prototype.
Working prototype: http://youtu.be/9-jXDERwk3U
Mechanics of how it self-adjust: http://youtu.be/X4YFPb60euE
( In this video I used gears instead of pulleys, but the mechanics are the same, and the blades/foils adjust the same)
Remove these ads by
Signing UpStep 1: Tools and materials
Metal Grinder ( with cutting blade)
Drill press
Drill bits
Rivet gun
optional Tap die set, ( Screw and bolts will work also)
Materials:
3 timing pulley. I used two 60 tooth pulley and 1 x 30 tooth pulley
2 timing belts ( Pulleys and belts purchased through "spd-si", Sprocket and chain would work as well)
multiple bearings . ( purchased online at "VXB")
Aluminum sheet metal ( any big box store)
Aluminum 1/2" inch tube, and 1 1/4" round tube ( Big box store)
1/4inch and 3/8 inch metal rods ( big box store)
JB weld ( epoxy)
Polymer spacers (easy to drill and cheap, purchased at big box store)
Flat aluminum bar 1/8" thick, 1 1/2 " wide
2 x 1/4 inch polymer thrust bearing
1 x 1/2 inch thrust bearing
Visit Our Store »
Go Pro Today »
Love your designs but what kind of motor have you used and how did you attach it ?
Tks
Love your design but what kind of motor is used and where is it attached ?
Tks
Since the blade rotates 360 degree ,an airfoil with lift would work great on one rotation , but then would be counter productive on the next.
We would need a neutral Airfoil that is aerodynamic but does not provide lift.
Thanks
Brilliant concept. Many thanks.
Here are a few more, if you search youtube:
Eolienne à axe vertical EolProcess
vawt with rudder 2 ( my favorite one )
Variable Pitch Vertical axis wind turbine
Lego rotating blade vertical axis wind turbine
Theres some debate as to the optimum amount of blades on this type of self adjusting VAWT. My theory was that if you want more power ...just make the blades larger. The more moving parts needed the more expensive and complicated it gets,
Excellent build quality, I highly recommend that you take a look at the work of Edwin Lenz and try his Lenz turbine, its an unconventional design for a VAWT but produces serious torque and is self regulating and self start from any wind direction. You have the skills with aluminium that would produce an excellent Lens turbine.
Just one thing I noticed is you mention the a chain drive would also work, from my own experience chains do not like running on a horizontal plain they much prefer the vertical plain, on the horizontal plain your sprocket need to be perfectly concentric to the axle as any play at all will have the chain coming off constantly, i had this problem on my first turbine attempt and rules out horizontal chains from all future designs.
Good luck and keep it up.
Sure, it may not be the perfect and-solution... But hey: It is a prototype.
And it seems to work.
What do you think are the main-benefits in comparison to "normal" propellers? May your idea be better in low-wind-situations than the common design we know? Or in very harsh winds?
Anyway: I am looking forward what may be changed and developed with this idea. Go on and dont listen to the Ney-sayers... :)
Typical propellers in high winds need to be shut down because of the vibrations.
Typical Propellers might be difficult to start in low wind
High rpm leads to unwanted noise
This design will work well in low and high wind speeds. ( I took a leaf blower to it and it still spun real nicely)
Possible future design changes:
Enclosed belt design ( to protect it from uv rays)
Polymer bearings on exposed parts(Eg: "Igus" bearings), ...Weather no longer issue ........
More aerodynamic foils
Your instructions and labeling were also great. Keep going!!
Have you been able to produce power measurements using it?
but won't you lose a little energy caused by the toothed wheels turning on each other?
so in you would want to hook a generator to it, won't you lose less energy than you gain with this design?
I suppose this WAVT is more efficient than others.
