3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Universal Nut Sheller (with forms)
Step 3Making the machine (Stator)
I have not spent much time going over the hardware for the project. The PDFs can be downloaded herehere. You will see that the hardware I use has only been slightly modified to fit the measurements of this machine.
1. Move the blue board and forms to a level surface. You'll need somewhere that you won't mind getting a little concrete and water on. I used the driveway.
2. Mix the concrete. A helper is always nice!
3. Weigh down the outer stator form and start filling it up. Tap the sides as you go to settle the concrete and move any air bubbles to the surface.
4. After the form has been filled, gently push the two remaining bolts into the concrete opposite of each other.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Jural
