3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Universal Nut Sheller (with forms)
Step 4Making the machine (rotor)
1. Take the rotor form and place it on top of some thing that will allow for the rotor shaft to pass through the 1/2 inch hole. It must also be high enough for the shaft to be centered vertically inside the form. I used a concrete block.
2. After placing the shaft into the form, pour six inches of concrete tapping constantly to remove air bubbles.
3. Center the shaft in the form. Any circular flat item can be used. Drill a 1/2 inch hole in the middle and slide it over the rotor shaft and into the form. It should touch the outer edges of the form. Take measurements from the shaft to the outer edge to make adjustments to ensure that the rotor will spin true.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Jural
