Step 24Pour Stator
iImage Information
MIX HARD SAND AND CEMENT IN A HALF AND HALF MIX, SAND BLASTING SAND OR RIVER SAND NOT CORAL OR FINE SAND. On a level surface, on a level surface pour concrete between molds, using a thin stick to remove air, only if necessary. DO NOT OVERFILL. Fill within one centimeter of the top of molds.LET SET AND HARDEN UNTIL A SHARP OBJECT CAN STILL MAKE A GROOVE IN SURFACE, hardening times vary with temperature and local cement type. Harden until cement has the the consistency of styrafoam. Use a bubble level in a few directions to assure it is level and straight. Note: Monitor the cement as it hardens. When the surface is hard, but can be scratched, remove inner mold and plastic liner for roughing up surface with wire brush.
