This machine was invented by Jock Brandis to shell peanuts at the request of a women's coop in Mali, later he would co-found an non-profit internation...
After locating the outer rotor mold, Wipe inner face of the outer rotor mold with cooking grease or heavy oil. This ensures an easy release of the con...
Install shortest threaded rods with nut and washer on both sides of outer rotor mold, exposing just enough threads to get a washer and nut on tightly....
Insert biggest shaft with two attached flat pieces into center hole THREADED END GOING IN FIRST. The threaded end must be facing down otherwise you wi...
Place outer rotor mold on stool, by sliding the shaft sticking out through the hole in the stool and through the pipe on the other end. The bolts stic...
Fit wooden clamp to exposed shaft, keeping inner rotor mold pressed down. Check the Lock Nut for tightness. The clamp is there to keep the mold from f...
Step 10: Pour Concrete Into Rotor Mold and Let Set
USE HARD SAND, SAND BLASTING OR RIVER SAND, AVOID CRUSHED CORAL. MIX SAND AND CEMENT IN A 50/50 MIX. Pour concrete into mold to within about a finger...
Note: These steps should be completed while concrete is still soft enough to brush surface to make it rough- WARNING: IF CONCRETE HAS LEFT TO SET TO L...
Place Rotor in mold on blocks with central shaft between the blocks. Hit side with piece of wood to loosen. Drop the whole assembly gently onto the bl...
Prior to prepping the mold for use, please check that side expansion joints are free and clear of any residual mortar, or foreign matter of any kind ...
Your kit should come with a plastic liner in it. This is used to help release the inner stator mold. However if the liner needs to be replaced this ca...
Once you've cut out the part for the plastic liner go ahead and seal the seam with electrical tape. If any liner is left above the mold trim it with s...
Insert and drop longeest threaded rods into the two remaining holes in the inner stator, these rods pass through the bottom of outer stator mold, and ...
MIX HARD SAND AND CEMENT IN A HALF AND HALF MIX, SAND BLASTING SAND OR RIVER SAND NOT CORAL OR FINE SAND. On a level surface, on a level surface pour ...
Leaving stator in outer mold, brush the inside surface of the stator using a wire brush using vertical brush strokes until the surface is rough. A mac...
Step 36: Turn Stator With Top Bracket Upside Down on Blocks
You will want to set the stator with the attached top bracket on top of concrete blocks (cinder blocks) or something of a similar shape, being careful...
Gently insert upside down rotor into upside down stator. The reason for having the stator up on blocks is to allow space for the rotor shaft to go thr...
Identify two threaded rods that also connect to top bracket. Identify the other end of the threaded rods that are holding the top bracket on. Place a ...
Cut and drill wooden supports. You can figure out where the holes should go by placing a support on the threaded rods then hitting the top of the wood...
Step 43: Turn Machine On Side Then Install Washers
You will now carefully, with two people turn the machine on its side, being careful to not let the shaft slide down through the bracket. Grease 4 (fou...
This is the Layout of the Metering Plates for the Sheller. Install the larger half-circle plates first so that that the notches meet. Then install the...
Set on box or 1/2 oil drum or other supporting object. To adjust for shelling bigger or smaller nuts raise or lower the rotor. To raise the rotor rele...
Proceed to introduce sheller to villages. Any small farms that grow peanuts, pecans, neem nuts, wing beans palm nuts, shea nuts and pine nuts have a u...
Step 48: Pedal Powered Agricultural Center (Coming Soon to an Instructable Near You)
This is a picture of our Pedal Powered Agricultural Center (PPAC), essentially it adds on to the Universal Nut Sheller (UNS) by making it pedal powere...
PDF Downloads As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
