Step 46Set on 1/2 Oil Drum and Adjust
Setting for Nut Size:
Shell a nut by hand. Drop through gap in metering plates. If the nut falls through the bottom of the machine, raise the rotor by turning the handle clockwise. If the nut fails to drop through, lower the rotor until it does. At that point tighten the lock nut.
Fine Tuning:
Shell 1 liter of nuts. If breakage rate is high lower rotor. If too many nuts are unshelled raise rotor. In the case of any nuts with a wide variety of sizes you may have to set for large nuts and seperate unshelled small nuts and pass through machine again.
Seeting for Volume of Nuts Shelled:
If nuts shell too slowly. Loosen wingnut on metering plate and adjust top plate to open gap.
Setting for Larger Nuts
If you want to set for larger nuts you may have to undo the two small bols on the the top bearing tube with an adjustable wrench and drop the entire assembly as far as necessary.
comments
Add Comment
Add Comment
