The pieces just fold together by hand into rigid forms, and you can take them apart and build into new shapes any time!
this is fun and educational for kids and adults alike, and you get a really nice lampshade when you are done.
As seen in ReadyMade Magazine, Dec. 2007/Jan 2008 issue
If you like our projects please check out the latest on Kickstarter
Remove these ads by
Signing UpStep 1: What you need
Below is the shape as an image, and i've also attached a DXF file.
You will need sheets of paper or plastic that allow light to get through. The stiffness of your material determines how large your pieces can be - stiffer material for larger pieces and larger lamps, thinner material for smaller pieces and smaller lamps. (see next step)
You will need a lamp fixture - just a raw socket on a cord. I found some nice ones at Ikea for $4, and some fluorescent bulbs. Use a compact fluorescent bulb so you can get more light without melting the plastic.
I experimented with a number of different plastics and sizes for the parts, here are my results:
- HDPE: works well, looks good, cheap and easy to get. I used 0.8mm thick stock for 8cm pieces (measured flat-side to flat-side). That's about the smallest you'd want to go with that thickness, you could go up to 12 or 15cm with that thickness. this is the least expensive plastic by far. One of the commenters suggested using plastic milk-bottles, which are made of HDPE, this is a good idea!
- Acetal (delrin): this seems to be the best choice for looks, it has the purest white color and best light dispersion (basically, looks just like acrylic except it doesn't crack as easily). I used 0.35mm stock for 6cm and 8cm pieces, and 0.5mm stock for 8-12cm pieces, and 0.65mm stock for 12-15cm pieces. It still is a little brittle and harder to work with than HDPE, and more expensive. if you cut this with scissors it will be somewhat tricky due to the brittleness, but possible.
- Vinyl: I did not try it, probably want to use thicker pieces since it is not very stiff. but you can use colors!
- Paper: I did not try paper but it should be good for smaller constructions.
- Laminated paper: this is a great idea suggested in the coments section. try laminating color tissue paper, then cut the pieces from that. very unique and colorful!
- Acrylic: too brittle, it will crack when you try to assemble. too bad!
- Nylon: has a yellow-ish look when lit up which makes it undesirable.
- for a large construction use stiffer material for the same size piece. ie, if you are making a lampshade with 12 pieces use thinner material than if you are making a shade with 100 pieces, assuming same size pieces.
Where to get it:
HDPE 1/32" sheet: sheet: http://www.usplastics.com item number 42584
Acetal sheet, 0.015" and 0.020":: http://www.mcmaster.com item number 8738K52 and 8738K53
polypiece.dxf31 KB
Visit Our Store »
Go Pro Today »
So did this guy steal this from you or what Dan?
i think if you are here at instructables you are more interested in cutting out your own pieces from an interesting material than paying someone else to do it for you.
These are the diagrams I found on this site. Good luck.
my id is Ali_naseem_1@yahoo.com
regards
Muhammad Ali
We used disposable cutting boards / placemats we got at Walmart. They have the same vine print green and black mixed in with some plain white. The photos don't really do it justice.
I think we're going to replace the incandecent bulb with and LED one for safety. Almost no heat from LEDs... and I already had a regular bulb melt through the plastic of another lamp I made.
Cheers
or not respecting Intellectual property?
http://www.iqlight.com/
The only thing that you need to do is quote the author of the material that you are using. Its the same with the clasical chairs of the Bauhaus or any chair, you can copy it and sell it but you need to quote the author of the chair.
Cheers
It doesn't look like there is any violation of intellectual property here. The original design was made in the 1970's so if there was a US patent on this kind of lamp, it has long since expired.
Just my 2 cents.
M
I made mine out of printer paper as a table ornament. It stands 16 inches or so tall and I cut my pieces, all 120, on my Silhouette SD. I reckon I could cut thin plastic too.
I'm working on a prototype ball with a special shaped piece to slot on to your ceiling pendant as the perfectionist in me needed it to hang right. My friend wants me to send her some and make a video assembling it, which I might just do.
Thanks so much for sharing!
Thank you for any assistance!
Ansley
I got some for AUD$17.20 per 30 (delivered price as I sniped 0.99c auctions and negotiated postage with 4 lots). Not as cheap as making them yourself, but the polycarbonate plastic is good quality, and I'm very pleased with the result.
Looks fantastic, thanks for the instructable!
So do you have your diagram on that? Thats an awesome design.
Thanks for any help!
Ansley
Well done!
does the red shade use the same pieces as given in this instructable?
Please let me know, I can see these as gifts for December
thanks
Jack
I converted the DFX over into a PDF. I called it IQlight.pdf
I was thinking about the HDPE material you recommended, and I got a thought. How about recycling 1 gallon Milk Jugs?
If you are interested in slide together polyhedra, check out this site.
George Hart polyhedra activities
http://www.georgehart.com/virtual-polyhedra/slide-togethers.html
Here is a picture of a ball I made from one of his patterns. I modified the triangle pattern, and built this ball out of CD's.
~Travis
Has anyone got the instructables for these . The GeorgeHart site is well worth checking out but there are no instructions. i'm sure members would love any and all Slide together polyhedra such as these.
I made the 30 square version as well, and it looks cool...
Does anyone know how to make one of these though?
http://www.origamitessellations.com/2006/01/17/identify-me/
The cool thing about this lamp shade is that you can open and close every individual compartment...
One point. WHERE CAN I GET XRAYS from as I only have 1 . Help please.
Sorry dont know yet how to "show' what I mean.
I am able to assemble the 30-elements lamp, and the 60-element lamp is also a piece of cake using videos found on the internet...
Can anyone provide a video or detailed instruction for the 120-element lamp please?
Thanks up front!
www.smartylamps.co.uk
Question, though. How did you go about attaching this to the lamp? I'll be doing a hanging fixture like some you have and would love to know how to attach it to my cord. Thanks!
i made sum and selling on trademe.co.nz for roun 30nzd but could post you one from auckland if u could pay through paypal, if u go to trademe and look up wiremu33 ive got them listed on there :)
I made a 30 piece lampshade. Here are some pictures:
One sheet of HDPE from usplastics.com (HDPE 24" x 48" 1/32" Thick) was enough for one lamp.
The lamp itself I bought for $3 off of craigslist; I used a 75W equivalent compact fluorescent bulb, which doesn't get too hot.
I hope other people have as much fun with this as I did.
Im using it in my bedroom :)
thank you so much dan :)
Thanks
i used the plastic covers from old lecture pads in different colours and it looks really cool
I made the relatively simple 20-piece lamp from recycled milk bottles. I laid the pieces out on the floor as illustrated on this site: http://themagazine.info/56/Pictures/MISC/IQlightThree.jpg and connected them one by one. Although the diagrams are very tiny, it does give you a good guide as how to put the structures together. I imagine that the 120-piece one would get rather confusing without any sort of instructions... good luck!
Joey
http://www.misterart.com
Carolina Pad Write On/Wipe Off Item # 6931225 1.44
An important thing to note is that if you want to hang it from something (bare bulb or even a keychain), simply insert the end of the cord/lightbulb into the shell and then pull it around any of the central connections. Because of the way the pieces interlock, it pinches the cord.
I had to install one of these and it took about twenty minutes to figure out how to assemble. Theyr'e great fun because you can make some REALLY big ones if you wanted to combine different sets. (There's a store in NYC's SoHo... forgot the name... that sells the actual lamps. It costs around $100 for one set. I've always wanted to make them myself, as that was too expensive for 30-something pieces of plastic.)
http://www.google.com/search?q=iq+light&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official is the Google site.
Here's a link for the instructions - http://themagazine.info/56/Pictures/MISC/IQlightThree.jpg
T.
http://www.mcmaster.com/
Cutting Delrin with a scissors was terrible. It's brittle and easy to crack. I would recommend Polyethelene.
The way you describe it is pretty much correct, except for the fact that it is a lot easier if you take the bottom element as a start. You have to assemble the first five pieces (the white ones in my diagram) forming the pentagonal base, and then you continue growing that bowl-like structure row by row (adding "circles"), until you get to the closing phase, where you'll eventually end up with the last five top pieces, that you'll just have to interlock.
It may look complicated, but you'll se that once you've done the first couple of rows it's pretty straightforward. Just keep an eye of the orientation of each piece.
Happy building!
http://www.christmaslightsetc.com/categorydetail.asp?categoryid=552
We used to make these as kids, in my Moravian church here in the states. we shorten the longer spires to make the star more rounded.
They may have kits that show how to cut and how to do the folding of the sheet plastic.
Then you could use that kit and its pieces as a template and make more of your own less expensively.
I wonder what would happen. I'm guessing a big blob of melted plastic, but it would be fun to find out!
It's called the IQ Light, see
or any of the numerous online shops carrying the lamp designed by Holger Ström.
Support creative designers and quality-focused companies by buying and loving their products.
