3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Universal lamp shade polygon building kit
Step 2Cut out your pieces
You can cut your pieces in a couple ways:
- trace them out with a marker, then use scissors or a knife. this is slow but can be done easily by anyone.
- make a "cookie cutter" out of sheet metal in the shape of the part. then heat the cutter with a torch and use it to stamp out the parts (only works for plastic)
- use a laser cutter
4 comments
Mar 28, 2009. 6:49 PMAercimete says:
exacto knife would work on thin materials....
Nov 20, 2006. 12:23 AMEmilyG says:
This is great! I saw this lamp at a fancy furniture store and I've been wanting to make my own. $100 for a die cutter and custom die sounds awesome. I too would like that link if you still have it. Thanks.
Nov 18, 2006. 9:08 PMthisisthechad says:
while it's likely that any laser cutter you might use will have a responsible person associated with it, it should be noted that using a laser on vinyl will create chlorine gas, which will kill you. Also, I did a project similar to this, and we used a custom die for the cutting, in conjunction with a simple die cutter-- the die (which is like a really sharp cookie cutter) cost around 30 dollars and the cutter was something a little ridiculous like 45 dollars... I can't remember the prices really well, but we ordered both on the internet and if you made a lot of lamps or split the cost with friends it wouldn't be too bad.
Nov 19, 2006. 7:35 AMdmeyer40 says:
thisisthechad, do you remember the URL of the site that you purchased the custom die from? Thanks!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
525
Author:dan(MonkeyLectric)
Dan Goldwater is a co-founder of Instructables. Currently he operates MonkeyLectric where he develops revolutionary bike lighting products. He also writes a DIY column for Momentum magazine.
