Step 9Wire It up
The pictures for this section can sum it up much better than I can, so I’m going to leave it at that.
If you aren’t sure which large speaker wire to attach your little ones to, just plug it in, touch the wires together, and if it works, mark those wires. If it doesn’t, Mark the other wire.
I solder all the wire connections together, just follow the same steps as step 4 for wire soldering.
Thanks for posting!
Check this out:
How To Solder!
Aaaaand GO!
Hi i love the this brand as well i have a asus switch and a single port WAP54G access point my question is i have Some really Big External Antennea for Standard SMA Connectors but like your Linksys i have those TNC connectors but the compaired to the normal once you can get from the shop such as a convertor from TNC to SMA it does not fit because its like Linksys changed the TNC connect by putting the Male inner on the Female Connector and Vise versa so my question is Where do you get Convertor Connectors from or should i just replace some High Freq BNC connectors or SMA connectors?
SMA
And just let you understand better its simple The Female Connector has a outer with a Screw like a CB UHF Radio Connector and on its Inside it has a Male Connector instead of a Female Connector like the Standard wich is Male PIN and male outer the Linksys Connectors are Mismatched and that is so you buy stuff from them.
i have one of these routers as well but only have a customizable version of tomato linux running. i would love to have expandable options, but dont think i would be upto doing this myself.
how much are you thinking of selilng the modded routers for? and what if i were to give you my WR54Gts in exchange?
With the addition of fans and boosting the transmit power, you're putting a lot of load on the built in power supply. Have you thought about bypassing it with a better supply? This might also fix the issues you were having with stability.
I have been thinking the same thing!
Definitely let me know if you come up with some sweet new cases :)
