Step 4Fixing the M button "bug"
I assume that you have already copied the contents of Flash Disk to your PC. Find the "\Flash Disk\MyGuide\" directory. Extract the Data.zip file (the one in the "MyGuide" subdirectory, not from the root of the Flash Disk). Find the file "config\keybind.txt".
Open keybind.txt and locate the
[CARPOINTA1000]section. Add the line
UP="MAINMENU"
The section should look like this:
[CARPOINTA1000]UP="MAINMENU"39="ZOOMIN_DISCRETE"37="ZOOMOUT_DISCRETE"
Overwrite the original keybind.txt file from the Data.zip and copy the updated zip archive to the SD card. Insert the SD card in the V7. Using Explorer, copy the Data.zip file from the SD card and navigate to "\Flash Disk\MyGuide\". Paste the file into this directory to overwrite the original file.
Be sure to copy it to the correct location, do not overwrite the Data.zip file in "\Flash Disk\".
The "M" button will now return the MyGuide software to the main menu, when pressed.
Add Comment
