iImage Information
In this instructable, I'll teach you how to unlock the ultimate administrator account in Vista. It allows you to change settings and modify files and move or delete folders without getting "administrator rights." You may be thinking, "I'm already an administrator!" And I'd answer, yes, but you don't have administrator RIGHTS... So let's get started.
Difficulty: Easy
Time: about 45 seconds
Step 11: Entering the Command Prompt as an Administrator
iImage Information
In this step, you have to enter the command prompt as an administrator, otherwise you will get the "access denied" error. This is the most important step.
First, open the Start Orb, then in the search box, type "cmd," and when the command prompt appears in the list, DO NOT JUST OPEN IT! You must first make sure it's highlighted, then hit CTRL+SHIFT+ENTER. It will open then in administrator mode.
Is there any way I can hack a password without using the admin. account, downloading any software, just by typing in a code in Command Prompt?
p.s. it said something about the passwords and usernames the first time, then the second time it said access denied.
is to right click and hit run as administrator
You can't delete folders in root without this? (That doesn't sound like something I'd want to install)
L
