(Unofficial) API Guide for MDrawBot MScara
Published
Introduction: (Unofficial) API Guide for MDrawBot MScara
This is a guide to the drawing API used by the MakeBlock mDrawBot kit mScara robot. http://www.makeblock.cc/
It’s a reverse engineering of their scara.ino and mDraw v1.1 python from Github (Aug.25,2015 commit) available at https://github.com/Makeblock-official/mDrawBot
The Makeblock mDrawBot kit is available in many Barnes & Nobles stores now and at the same price as mail order (even cheaper if you are a B&N member!)
This document's purpose is to provide a guide for creating alternative programs to mDraw, the program that it normally used with mScara, such as linux command line tools or interconnection to other CNC type plotter programs.
Note that since mScara isn’t an X/Y Plotter, the coordinates require conversion to the arm coordinates to correct for distortion, same as your brain has to do to control your hand. This is done in the scara.ino software, but could require you to fine tune X/Y coordinates sent to mScara to account for distortion. I have found that its defaults are adequate for most small drawings.
This guide and several example python programs are available from GitHub at https://github.com/rgrokett/mdrawbotAPI
Step 1: Start Off Using MDraw
When you use the “Update Firmware” function in the mDraw program, you are actually downloading a compiled hex version of the scara.ino program to the Arduino Orion. This program handles the conversion of a subset of CAD Gcode into the stepper motor arm & pen motion.
So before trying to do anything using this API and its examples, be sure your mScara is working correctly with the MakeBlock mDraw program and its included examples.
Once you have advanced pass this stage, then you can try your hand using this API.
Abbreviation
Description
CAD
Computer Aided Design
CNC
Computer (or computerized) numerical control
https://en.wikipedia.org/wiki/Numerical_control
G-Code
G-code is a language in which people tell computerized machine tools how to make something.
https://en.wikipedia.org/wiki/G-code
Step 2: List of API Commands
Once the firmware is updated into Arduino Orion, it will remain even after power off. When you power up the Arduino, it will automatically run the program again, open its USB serial port and await the Gcode commands shown below.
List of available mScara commands:
Command
Sub
Function
Example
M1
Pen Up/Down
M1 140 = Down
M1 160 = Up
M2
Save Pen Up/Down positions
M2 U160 D140
M3
Set Stepper Aux Delay
M3 0
M4
Set Laser Power
M4 50 to M4 100
M5
Save Robot EPROM settings
M5 A0 B0 M168 N206 D50
Note: requires COM port to be closed/reopened to reinitialize
A
Motor A Direction (forward/reverse)
A0 or A1
B
Motor B Direction (forward/reverse)
B0 or B1
M
Arm L1 length mm
M168
N
Arm L2 length mm
N206
D
Speed 50-80%
D50 to D80
M10
Return EPROM settings
Send: M10
Recv: M10 MSCARA 168 206 -373.99 0.00 A0 B0 S60 U160 D140
Arm L1 Arm L2 Home X Home Y plus below:
A
A0/1
B
B0/1
S
Speed 50-80%
S50 to S80
U
Pen Up position
U160
D
Pen Down position
D140
G1
XYZ Move
G1 X-205.55 Y175.75 A0
Note that positions are not true X/Y due to arm movement. Requires math conversion.
X
X position
X0.0 to X-375.0 (approx. range in mm)
Y
Y position
Y0.0 to Y375.0 (approx. range in mm)
Z
Z position (not used)
F
Stepper speed mm/min
Defaults to M5 D command
A
Stepper aux delay factor
A0
G28
Move to Home
G28
P1
Return current X Y position
Step 3: Sample Sequence of Commands
Below is a sample of a typical transmission from the PC to the Arduino Orion. The Orion converts these commands into the pen motion.
Sample sequence
COMMAND
DESCRIPTION
M4 0
Set Laser power to 0 (optional)
M10
Retrieve EPROM settings
M1 130
Pen Up
Move to location
M1 90
Pen Down
G1 X-195.55 Y185.33 A0
Draw to location
... (more G1 pos)
M1 130
Pen Up
G1 X-221.53 Y123.25 A0
Move to location
M1 90
Pen Down
G1 X-231.53 Y123.25 A0
Last Draw point
M1 130
Pen Up
G28
Move to Home
Step 4: Example Usage
An example of using these commands follows below. To send these commands, I used a Linux server connected to the Orion via USB. This is for Command Line interface, not for GUI.
NOTE: If you use a Raspberry Pi, you must either leave the Orion’s Power Switch turned ON or use a Powered USB Hub. The Raspi does not deliver enough current to keep the Orion powered up by itself.
NOTE: You must have previously installed and operated the mScara using mDraw software on a PC so that you know the mScara is working properly before proceeding. Also sets the default EPROM settings.
1.Plug in the USB cable between the Linux server and your Arduino Orion.
Note that this port must be able to run at 115200 baud. Not all servers can do that!
2.On the Linux server:
$ ls –lart /dev/tty*
Look for the last entry (newest date). This would be the USB serial port.
crw-rw---- 1 root dialout 188, 0 Nov 1 19:01 /dev/ttyUSB0
On Raspi, it would be something like /dev/ttyACM0
3.Create a test python program to talk to the port: (substitute your port)
$ nano porttest.py
import serial, time
ser = serial.Serial('/dev/ttyUSB0', 115200, timeout=20)
time.sleep(2) # just give some time for port open
ser.write('M10' + '\n')
print ("EPROM:"+ser.readline())
print (ser.readline())
print ("FINISHED")
ser.close()
Be sure the mScara motor switch is turned on and previously tested using mDraw.
Then run the test:
$ sudo python ./porttest.py
You should see something like:
EPROM:M10 MSCARA 168 206 -373.99 0.00 A0 B0 S60 U160 D135
OK
4.There are several other test programs available in the API guide github directory at:
    • Casting Contest
      Casting Contest
    • Oil Contest
      Oil Contest
    • Clocks Contest
      Clocks Contest
