Unorthodox airsoft tactics to help you win the war
 by oniman7
This instructable is all about finding ways to win the war. Ways nobody would expect. As such, improvisation is a must. This guide will give you suggestions on unorthodox ways to give you advantages, but will also get you thinking on how you could improvise your own playing style to win. I will tell you now that this is not recommended for backyard airsoft players. Some of these certainly could be used for backyard playing, but it's mostly for hardcore players. That said, have some fun reading this. I'm going to invite Jakee117 to help out, so subscribe to both of us if you enjoyed this instructable.
Step 1: The supported buddy position.
This is one that's popular among snipers when there's a lack of support for them to shoot from, but I'm going to teach you how to adapt it for field use.
How it works: You will have two people. Out of the two, the one with the smaller gun will get in front and crouch. The person behind them will also crouch, resting the gun barrel on his buddy's shoulder for extra support. Ideally, the person should have the longer, heavier gun.
Sniper/spotter adaptation: The spotter usually has a smaller gun with a higher rate of fire. He will crouch down, with his gun at the ready. The sniper will then rest his gun on the spotter's back. Because of the difference in the guns, the sniper will take his time to get anybody at a set distance (depending on the quality of the guns, it would be, say, 125 or more feet away.) Using this example, the spotter would use his automatic/semi automatic weapon to take out anybody who got within 100 feet. The spotter is more likely to be hit because he's right up front. For optimal support for both people, the spotter will be supported by a low wall or other defence, and the sniper will rest on his back. This is good for a defensive position, when the sniper and spotter have been discovered.
Ambush or undiscovered position: You will have hopefully found a good place to hide. If not, you have to work fast. It doesn't matter who uses their buddy for support, but it should be the person with the longer gun. In this case, both people will communicate. You will both pick out one target, and shoot at the same time. If you're in a hidden or defended place, you both should be able to take out two targets or more before they've discovered your location, which is very effective for two people.
Capture the flag: When playing capture the flag, you can use this position. When you find the flag, you should automatically fall into this or some other defensive position. After you've looked around and found no enemies, the person in front (having the lighter gun) should run up and grab the flag. If necessary for a faster grab, the person running can leave their gun with their buddy, but this makes it harder for the buddy if they need to run.
Well, those are basic adaptations of the supported buddy position. However, this entire instructable should teach you how to improvise, and it includes things such as this.
It should look a little bit like the picture, but the spotter might have a gun.
1-40 of 111Next »
skullzluver98 says: Sep 22, 2010. 4:42 PM
Oh man!!!!!!!!!!!! I'm going to get my butt kicked this weekend! I'm playing on my friend's property which he knows inside and out. He also has 30 or so air-soft guns! I have one 250fps single shot air-soft rifle!!!!!!! My only counterstrike is about two smoke grenades, some firecrackers, and a stink bomb! Please help me!!!!!!!!!!!!!!!!!! What do I do!!!!!!!!!!!!!!!!
jared 70 in reply to skullzluver98Nov 15, 2011. 7:50 PM
If your in a group use an ambush or if your alone just find an thicket of shrubs and wait till he passes and hit him in the rear.
atomiclegocreations in reply to skullzluver98Aug 2, 2011. 2:13 PM
ok, so first you'll need about 9000 BBs, two hundred different areas to hide, 2 sidearms, 50 bucks and some sort of way to take over the battlefield. Any questions- wait, this was posted a year ago!
Kolf35 in reply to skullzluver98Mar 4, 2011. 12:29 PM
First of all,I no that u posted a really long time ago,so don't make any cracks.
Now for the advice.RELAX!!!!!!!!you'll never win like that.2nd,nobody can know a big-enough playing field well enough that he(or she)knows every hiding spot unless he's lived there for a really really long time.if there're trees,then climb them before the game to get a feel for it.also,be very quiet.sneakiness is the key.
Thats all,just follow that and your good
Hitman227 in reply to skullzluver98Nov 27, 2010. 4:40 PM
Buy a ghillie suit if possible. If not go all guerilla like oniman said.
oniman7 (author) in reply to skullzluver98Sep 22, 2010. 6:26 PM
Lost the firecrackers and stink bomb. They won't help. If he has a big property, go guerilla on him. Be sneaky until you find him, and then sneak close with your gun ready to fire. Fire when you're sure you can hit, and don't stop shooting until he's out.
Dr.Earl Insanity in reply to oniman7Aug 25, 2011. 7:14 AM
agreed...I use this tactic...being sneaky makes up for my cheap gun...
JaronNeumann says: Jul 3, 2011. 2:40 PM
Your right about this. I went paintballing and destroyed 6 people while my freind and i were using this tactic. i like your style.
airsoft master 25 says: Jun 25, 2011. 5:07 PM
how would the sniper even see the dudes hat is blocking the scope
geodez says: Jul 13, 2009. 8:06 PM
looks like his binoculars are backwards.
airsoft master 25 in reply to geodezMay 15, 2011. 6:15 PM
yeah
Kolf35 in reply to geodezMar 4, 2011. 12:30 PM
No kidding
geodez in reply to Kolf35Mar 4, 2011. 8:09 PM
Yes, and also that rifle barrel on your shoulder (with a standard rifle) is a good way to lose an eardrum.
predatory meatball in reply to geodezJul 30, 2010. 12:11 PM
nooo, that thing on the end MAKING them look backwards is just a flash kill... it gets rid of the suns reflection on the lens, making less noticeeable, smart one
geodez in reply to predatory meatballJul 30, 2010. 2:37 PM
No... Really. (Sarcasm.)
oniman7 (author) in reply to geodezAug 2, 2009. 10:26 PM
lol. That they are.
geodez in reply to oniman7Aug 3, 2009. 8:06 AM
fail.
oniman7 (author) in reply to geodezAug 3, 2009. 5:10 PM
I wonder what he could possibly be looking at. Maybe he's got pictures inside the lenses.
predatory meatball in reply to oniman7Jul 30, 2010. 12:13 PM
its a FLASH KILL stupid! it hides the len´s reflection still letting you see through
oniman7 (author) in reply to predatory meatballJul 30, 2010. 2:12 PM
This has been covered. Thanks for your contribution. By which I mean, thanks for nothing.
Kolf35 in reply to oniman7Mar 4, 2011. 12:34 PM
Lola (and no I didn't misspell lol)
bounty1012 in reply to oniman7Dec 19, 2009. 7:01 PM
;D
geodez in reply to oniman7Aug 3, 2009. 8:09 PM
it's a viewfinder!
Kryptonite in reply to geodezOct 1, 2009. 4:19 AM
Might want to check the above comment from Yeahbutdoesitwork.
geodez in reply to KryptoniteOct 1, 2009. 5:02 PM
i commented before he did, so i was not wrong, i was simply mistaken.
Kryptonite in reply to geodezOct 2, 2009. 4:01 AM
Yea I knew he commented before you, that's why I thought I'd tell you. Less confusion is equal to or greater than more win.
geodez in reply to KryptoniteOct 2, 2009. 9:24 AM
yes.
oniman7 (author) in reply to geodezOct 1, 2009. 5:36 PM
lol "I wasn't wrong, I was simply mistaken".
geodez in reply to oniman7Oct 1, 2009. 6:03 PM
yes.
oniman7 (author) in reply to geodezOct 1, 2009. 6:07 PM
They're the same thing.
geodez in reply to oniman7Oct 2, 2009. 9:23 AM
and?
oniman7 (author) in reply to geodezOct 2, 2009. 12:14 PM
I just thought it was funny.
geodez in reply to oniman7Oct 2, 2009. 2:00 PM
oh.
Rigor243 says: Dec 13, 2010. 5:07 AM
In my opinion, this image is the perfect sample how to NOT stay behind a cover.
Maybe it's comfortable to place the barrel and the arm on the bags, but slows down taking cover. And in the other hand, you can'1 hide and pop up fast another positon.
The other misstake in the picture is the elbow. - He is a bigger target, and from the right it's over the cover. I'm always holding my elbow tight to the chest. (maybe because i prefer cqb - it's fun to see, and hit the elbow before the gun appears to shoot).
If you know where to shoot, you can preaim behind the cover ( imaging the target positon and aim a bit lower to compensate for the displacement
while you move out from cover).
If you want to place the barrel on the cover, just place the tip of the barrel, so it's comfortable, and you can also can fall back fast to the cover.
When i'm keeping head up, and know the enemy's positon, i fire some aiming shoots, to feel the distance and the wind, and comensate, so when the enemy's popping out, my shoot will very precise, and also i can get to the cover very fast.
Use red dot (coverd lense) or turned to the side position - to aim with booth eyes open. And also if you'r turned to the side you are smaller target from front.
- sorry for the bad english.
Rigor243 in reply to Rigor243Dec 13, 2010. 11:16 PM
(I was thinking about step 3 before Keep-your-head-up.jpg)
There are lot of advantage useing booth eyes.
1. wider field of view - more information + mutch better peripheral vision
2. stereoscopic vision, - better feel the distances
3. don't get tunnel vision.
Without red dot, the side position allow you to aim and see the target without getting double vision - try it!:).
joshfedo says: May 21, 2010. 5:30 PM
ive had to do this a couple of times lol
MrMadmonkey4 in reply to joshfedoDec 5, 2010. 1:33 PM
lol yea me too and it worked, the guy freaked out
toxincool says: Nov 3, 2010. 8:22 PM
i like using duck tape
abadfart says: Oct 1, 2010. 10:44 AM
i had to pull a bluff last time i went paint balling and busted an o ring on my tank and a good distraction is to set off some smoke bombs and just leave 2 or 3 people to take cover and fire then the rest come in from the back way
Slayerfan666 says: Aug 31, 2010. 12:10 AM
I bought a pair of handcuffs from rite aid in the toy aisle, lol but hey they're real metal and they work so ya.
1-40 of 111Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
