Untangle and De-frizz a Long Wig
90,365
42
7
Published
Introduction: Untangle and De-frizz a Long Wig
About: Irl satan
I'm going to show you how to detangle and de frizz a long wig. *WARNING: ONLY DO THIS IF YOU KNOW YOUR WIG IS HEAT RESISTANT, OR ELSE IT WILL MELT! this also might damage your wig a little bit, but if you are reading this tutorial, your wig is probably already damaged lmao.
Step 1: Materials
-flat iron
-spray bottle
-wig conditioner (can usually get this at beauty stores)
-water
-towel
-wig brush
Step 2: Make the Spray
Mix a little bit of the conditioner and water into the spray bottle. I'd say about a quarter sized amount of conditioner and the rest water.
Step 3: Other Steps .3.
First spray the bottom of the wig and brush it with the wig brush. Then spray the bottom again and flat iron it. It should make a sizzling noise. If your wig is really messy, seperate into different sections. Then move up the wig and repeat. My wig is really messy at the top so I won't even try and brush it out.
Step 4: Braid It! (optional)
You don't have to braid it, I just did because it does help it not get thangled. But it does get wavy when u take it out so you'd have to flat iron it again. If u don't braid it, i'd recommend that you keep it in the wig net and bag it came in. ** make sure that the wig is completely dry before you store it in a bag kr else it might get moldy or smell bad.
3 People Made This Project!
  • Stick It! Contest
    Stick It! Contest
  • Pets Challenge
    Pets Challenge
7 Comments
i have a miku wig as well, and it's really knotty. thank you!
Omg you are a genius! Thank you!!!
Only if your wig is low quality or synthetic. I had a synthetic wig that I tried this on, and I just applied the mixture, waited for it to dry a little, and brushed it out. It worked great.
I recommend that you use a boar-bristle brush. It won't tug on the wig, and it smooths it out. You can find those at Walmart. :)
Oh my goodness! Thank you so much! I did this, and it worked wonders! I thought I was never going to be able to restore my wig, but it worked! Thank you so much!
