Unusual Uses for Toothpaste
31,567
220
39
Published
Introduction: Unusual Uses for Toothpaste
About: Mom of 2 kids, Food Blogger, Foodie :)
We all use TOOTHPASTE to keep our teeth clean and white. Do you know, we can use toothpaste for other purposes?
Read on below to know the amazing unusual uses of Toothpaste.
I hope this post will help you all. Thanks
Step 1: Clean Silver Item
Wet the silver item and then apply small amount of toothpaste on the item. Scrub it with wire/sponge scrubber until it takes away the black appearance.
Let it sit for 5 minutes and then rinse it thoroughly with running tap water.
You will see the silver item looks brighter and shinier.
( The above pic is one wash. If the tarnish is still there, repeat the process for 2-3 time. you will see the immediate improvement )
Step 2: Clean Kitchen and Bathroom Chrome
Cleaning chrome with toothpaste gives awesome result. Take a small amount of toothpaste in sponge, rub it on chrome and then wash thoroughly with water. That's all! It will look just like a new kitchen/bathroom chrome
Step 3: Remove Stains From Fabric
If your favorite dress got stains with ink or lipstick. Do not worry. You can just wipe it off with toothpaste.
Wet the stained area and apply small amount of toothpaste in it. Rub it with both hands until it wipe away. Wash the toothpaste thoroughly with water. No more stain in the fabric :)
Step 4: Remove Crayons From Wall
My little one is gonna be 3 in few months. She likes to scribble in walls instead of her colorbook. I have tried many stain removers to get off those from walls. But toothpaste works great.
Apply some amount of toothpaste on scribbled area, wet the sponge with water and scrub it until it all gone. Finally wipe all the toothpaste with wet cloth. That's all.
Hereafter no worries about crayons mark on the walls.. Happy daughter, Happy mommy :)
Step 5: Clean Kitchen and Bathroom Sink
Instead of using sink cleaner, you can use toothpaste to clean kitchen/bathroom sink.
Apply some toothpaste on wire scrub and scrub the sink until all dirt gone.
wash the sink well with water.
Step 6: Remove Stains From Plastic and Wooden Surfaces
Toothpaste easily removes the stains from plastic and wood surfaces.
Apply some amount of toothpaste on stained area, wet the sponge with water and scrub away all the dirt.
Step 7: Soothe Minor Burns
For minor burns ( it shouldn't be open wound) , you can use toothpaste for instant relief.
Wet the area with cold water, apply some tooth paste on it. It will immediately soothe the burning sensation.
Step 8: Clean Smell From Hands
I used to wash my hands with toothpaste, after cleaning fish. It deodorize the smell from hands.
Apply some toothpaste in hand and rub it with both hands. Then rinse under water. It immediately take away the stinky smell from hands.
    • Stick It! Contest
      Stick It! Contest
    • Oil Contest
      Oil Contest
    • Casting Contest
      Casting Contest
    39 Comments
    Hi! Could you please elaborate because it sounds like an awesome idea! Toothpaste as a masking agent for painting! Please share your knowledge... Thx...
    I am a member of the Mandalorian Mercs, a Star Wars costume club. We do custom versions of the armor made famous by Boba Fett and Jango Fett. Basically, we've used toothpaste as a masking agent to create the illusion of weathering. First, you would paint your item with a good primer. Sand any rough spots smooth, then primer again until the surface is how you want it. Next, lay down your base coat. For our costumes, this often means a metallic color. I'll do 2-3 metallic base coat layers. Next I'll decide where my scratches, blaster damage, and paint chipping will be. Good rule of thumb here is to make it natural. High spots and anything that might rub against something else. Lay down a coat of toothpaste in the spots you want the metallic base to show through. Continue with your secondary colors, adding a bit more toothpaste to the same areas. Remember to try and keep the weathering random. Once you've got all the colors on that you're going to use, let the object dry completely. Once that's dry, simply use a damp rag or paper towels to wipe away the toothpaste and, voila! You've just made your item look like it's been beat up! For added depth, we recommend that you give your prop a "blackwash" to simulate years of dirt and grime. For my blackwash, I use a mix of brown and black acrylic paint. This I'll brush on and then wipe off the surface. Make sure you get the paint down in the cracks and crevices, just like real dirt and muck would! And that's it, doesn't take much, and you end up with a fantastic looking prop. I attached a couple pictures of my costume so you can see my outcomes!
    jdevisser - Thanks a lot for sharing!
    we can use it on nose to remove black heads..:p
    I would add a step saying to use it for repairing discs, but, you would probably get a lot of comments saying things like "It doesn't work!!!" and "How dare you!!!". It's worked for me before though.
    Exactly! I did that for CD's & DVD's as well :)
    Do you know if it will work repairing scratched reading glasses? Whether they're made of glass or plastic? TY...
    You can also use toothpaste to clean your car´s headlights, as has been seen here in lots of Instructables
    Tried all of those things to clean my headlight lenses and NOTHING worked. Even tried the crap you can buy just for it. The ONLY thing that worked was to order new headlight assemblies from amazon. They look better than new now!
    You can also clean your headlights with Bug Spray. I tried it and it made the lights really SHINY and BRIGHT!
    Wow it's amazing and realy work. My chrome is too dirty i mean brown and white spots of soap it clean my chrome and it is very shiny ♥♥♥♥♥
    So simple but usefu
    You can also use it as a thermal paste for heat sinks with electronics.
    seriously? hahahah
