Introduction: Up-Cycled Aluminum Can String Lights
I was inspired to create these light covers when looking for decorative lights for my room. Many of the lights I found were $30 for a strand of ten lights that aren’t easily replaced, so I thought I might as well make some homemade ones using recycled materials and put them on the Christmas lights I already had.
Although this project is doable on your own, it is faster and more fun to do with friends. I recommend doing some of the more tedious steps of this project while watching a movie or listening to music. These light covers are great for decorating any space from a dorm room to an outdoor patio!
This project is 10 steps and takes about 6 hours to make 20 covers.
Step 1: Gather Materials
- Aluminum cans (half as many as the number of light covers you want to make)
- Print out of template provided (used recycled paper if possible)
- Scissors
- Sharpie (fine point)
- Tack
- Needle and thread (small enough to fit through a tack hole)
- Sand paper (I used a spare sheet of aluminum oxide type paper and 100 grit)
- Craft paint or spray paint (I used some old gold spray paint for wood and metal that I had from a previous project)
Wire (thin and malleable)
Step 2: Wash and Cut Cans (20 Min)
- Rinse out all of the cans
- Cut each can into a flat sheet of aluminum (follow along with the diagram)
- Place can right side up
- Puncture a 2 in. vertical slit into the side of the can using the knife (arrows)
- Cut using the scissors all they way down the side of the can from top to bottom using the slit as a starting point (dashed lines)
- Cut using the scissors horizontally around the can at the top and bottom to cut out the side of the can (dashed lines)
- Set the sheet aside and recycle the top and bottom pieces
- Repeat with each can
Step 3: Sand Aluminum Sheets (5 Min)
- Lightly sand the outside (logo side) of the aluminum sheet
- Repeat with each sheet
- This will make the paint stick well later
Step 4: Trace the Templates and Cut Out Shape (1 Hr)
- Print and cut templates
- Lay out both templates on the aluminum sheet like the diagram above (I used a small roll of tape on the back to hold both down at the same time)
- Trace around the templates using a sharpie
- Put paper templates aside
- Cut out the shapes
- Repeat with each sheet of aluminum
Step 5: Draw Fold Lines on the Shapes (5 Min)
- Follow the lines on the diagram and draw dashed lines on the outside (logo side) of the cut out
- Repeat with each shape
Step 6: Create the Pattern on the Shapes (2.5 Hr)
- You can follow my diagram or create whatever design you want on this step
- Make sure to tack the holes that are colored red on the diagram since you will use them later for sewing and attaching to a light
- Don’t worry about making the holes perfect
- To follow my diagram, you will need a tack
- Punch tack holes with the outside (logo side) up so that the holes are smooth on the outside of the cover
Step 7: Fold Together Shape to Create the Cover (10 Min)
- Fold inwards on the dashed lines you drew to create an octahedron (eight sided diamond shape)
Step 8: Sew the Cover Together (1 Hr)
- Follow the red dots on the diagram
- Use a needle and thread to tie together the points tightly
- Thread together in numerical order
Step 9: Paint Covers (30 Min)
- Spray Paint
- Lay covers out on newspaper outside
- Spray from 12+ in away
- Turn covers over as needed after 5 min of drying to cover each side
- Let completely dry for 30 min
- Craft Paint
- Hold cover on the inside and paint the outside
- Set on a sheet of newspaper to dry
- Let dry of 30 min
Step 10: Attach Covers to Lights (20 Min)
- Cut a 4 in piece of wire
- Follow the diagram to bend the wire
- Bend in half
- Bend each end of the wire
- Put wire through two top holes in the center on opposite sides of the opening of the cover
- Put cover over light and bend wire to hang over light strand
Step 11: Hang Up Your Lights!
Congrats you finished!
Make it Glow Contest 2016
Trash to Treasure Contest 2017
