Introduction: Upcycle Metal Food Tins Into Storage Containers
About: Hi! I'm a slightly feral mountain hermit that likes to be helpful. I do community management at Instructables & Tinkercad. 🙌 Want to hear me chat about making? Search "CLAMP Podcast" on YouTube or your favorit…
I recently got a new craft area, and I've been working to make it pretty and functional. Add to this a cat that loves to eat any sort of thread or felt left out in the open, and I really needed some decent storage and quick!
And why overpay for horrible clear plastic containers when you can make your own? All it takes is a little time and spraypaint and BAM! Ugly holiday themed metal tins are turned cute storage tins. :D
I don't even want to show you what my craft storage looked like before.
Step 1: What You'll Need:
  • spray paint
  • masking tape/painter's tape
  • metal food tins
Check your local thrift stores for metal tins - they seem to be everywhere! I went to the Depot for Creative Reuse in Oakland, and they had a huge selection of them - I got four of them for $2.50.
Or wait until the holidays and dig in your neighbor's trashcans.
As far as paint, make sure you're using something made for painting metal. I'm using Rust-oleum because I've had success with it before. And the ultra cover stuff I'm using works really well. :D
Step 2: Wash Them Tins
Chances are they will still have little bits of crackers, cookies and popcorn left in them. Mine certainly did!
I just washed mine in the tub using a little dish soap and let them air dry outside. :)
Step 3: Paint the Base Coat!
I chose white for my base coat - it works well as a primer of sorts and makes the tins look nice!
I cut up paper bags to use as a painting surface, but did this in my backyard because it was super windy the day I did it, and I knew my landlady might not be too excited if I painted all over the back porch. :D
You'll want to do two layers for good coverage. Make the layers nice and light - don't hold the can too close or spray so long that you get drips!
Do one thin layer, trying to cover as much as possible and then go inside and watch an episode of something (might I recommend Downton Abbey or Doctor Who?) or jump in place/dance around for a while. Then go back out and do another layer. Make sure you get all the edges!
You'll want to let the base coat dry/set for at least 24 hours after the second layer before you add any additional tape or mask them for painting. :D
Step 4: Masking!
I can't give you any official designs or recommendations as I am the Queen of Winging It. I just went with it. I did stripes in a chevron style. :)
Make sure to press the tape down firmly, especially around lips and ridges that will probably occur around the edges of the tins. Also make sure to cut the tape with scissors instead of tearing it - this will help you get a cleaner design and make the edges of the tape easier to line up.
Step 5: Paint the Top Coat!
I chose yellow and green for my top coats - I wanted the tins to be cheery but not neon. :P
The top layer only needed one coat since it's going over a nice white base. I set the tins right side up because I thought it was silly to paint the bottoms with the top coat - ain't nobody gonna be seeing the bottoms!
Be use to use a light hand while spraying - streaks and drips are much more noticeable when using colors. Going too heavy with the paint can also cause the tape to raise and ripple.
Once they're painted let them dry for a while - I let mine dry overnight.
Step 6: Peeeeeeel!
Peel the tape off nice and slow!
You might find that you have some places where the paint comes off. I know I did! This is normal when you paint metal. :P If you'd like to fix the spots, spray some spray paint into a small container (I've used the cap of the spray paint with great success) and paint it on using a tiny brush.
I did not fix mine because I was feeling good about them, small paintless spots and all!
Enjoy your new and extremely cheap storage containers! Mine gave me enough room to get all my sewing accessories out of the way. :D
Fix & Improve It Contest
