Upcycled Jewelry Rack
Published
Introduction: Upcycled Jewelry Rack
About: I'm currently a SAHM with two girls - aged 4 and 10. A former aspiring artist, I am now an aspiring author. I fill my time volunteering at school, trying to write, and doing crafts when I have writer's block.
Get your baubles out of the jewelry box and out on display, with this upcycled, shabby chic jewelry rack!
Step 1:
JEWELRY HANGER TUTORIAL
SUPPLIES:
Wooden plaque with robe hooks or any plain wooden plaque
Drawer pull knobs—enough to fill width of plaque, odd number
Wood filler
Sand paper
Drill and drill bits
Paint & paint brush
Wire cutter multi-tool
I started out with one of those wooden plaques with robe hooks on it. It was pretty old and beaten up, lots of scratches on the hooks and the finish was peeling off the wood.
First, I removed the robe hooks and set them aside with their hardware.
Step 2:
The holes for the existing hardware were a lot larger than the bolts for my new knobs, and I wanted to reposition everything anyway.
So, I taped over the holes on the back of the board, and filled in almost all of the holes with wood filler. I did leave the top two holes at the corners, so I would be able to hang it on the wall when I was done.
Step 3:
The really time consuming part of this project is waiting for things to dry. The wood filler took about 24 hours. Just squeeze it into the holes, smooth it out with your finger and leave it alone until tomorrow. Don’t worry about getting it neat—the whole thing will be sanded before it’s painted anyway.
The next day, with the wood filler dry, I was ready to drill the new holes. First I needed to figure out the positions of the new knobs, so I taped a dressmaker's measuring tape to the board and played around with the spacing of the knobs until I came up with something I liked.
I knew I wanted the fleur-de-lis in the center, and the knobs with backing plates positioned on the bottom row. I also wanted 2 inches between knobs. I marked out the positions and got ready to drill the new holes.
The bolts that came with the knobs were 1/8" diameter, so I drilled the new holes with a 5/32" bit.
Step 4:
Once the holes were drilled, I was ready to sand and paint. I used an electric palm sander, so it only took about three minutes to remove the old finish and sand down the wood filler. Good, old fashioned sand paper and elbow grease will get the job done too, it's just going to take a bit longer.
Once I was done sanding, I used a barely damp paper towel to wipe off the dust, and started painting. I used artist's acrylic paint from a tube - Cadmium Yellow - mixed with a bit of white and a tiny bit of water. Because I was painting raw wood, and I wanted a good opaque finish, I ended up applying four thin coats.
The light in my craft room is drastically different from the light in the bedroom where this would ultimately hang. Once the final coat of yellow was dry, I took it into the bedroom to get an idea of how it looked. It wasn't good - in fact, I hated it.
To remedy the situation, I went over the whole thing with one coat of the latex interior gloss paint that we used for the trim work throughout the house. Then I went over it lightly with a piece of sandpaper, to distress the piece, and remove some of the white to let the yellow show through.
Step 5:
With the board finished, I was ready to begin attaching the knobs. Since my board was not as thick as a cabinet door or drawer front, I needed to shorten the bolts that came with the knobs.
My husband does a lot of electrical work, so he had a wire stripping tool that can also be used to cut screws. Using that, I was able to cut all of the bolts down to the length I needed. A word of warning though - because the knobs came from a variety of manufacturers, some of the bolts were easier to cut than others, and some I was not able to cut at all. It does require a lot of upper body/hand strength.
With the bolts cut, we decided to countersink the holes on the back of the board, using a countersink drill bit. We attached the knobs, tightening each bolt with a manual screwdriver.
Because all of the knobs I used were solid metal, the whole rack ended up being fairly heavy. We hung it on the wall using wall anchors, just to be on the safe side.
Step 6:
So there you have it - all prettied up and hanging on the wall.
My older daughter has requested that I make her a hat rack using the discarded robe hooks, so stay tuned for my next project!
    • Pets Challenge
      Pets Challenge
    • Oil Contest
      Oil Contest
