Upcycled Phone Case
Introduction: Upcycled Phone Case
You Will Need :
Tape (Clear)
Box cutter
Measuring Tape
Step 1:
Measure out the dimensions of your phone.
Step 2:
Cut the Cardboard box to fit the dimensions of the phone and tape the pieces together.
Step 3:
Use the tape to tape the front of the phone case, this tape is used as a screen protector.
Step 4:
Once you've finished taping the cardboard, you're done !!!
Step 5: Upcycling Vs. Recycling
Recycling and Upcycling are both great ways to get rid of waste. For recycling we are taught about the three R's; Reduce, Reuse and Recycle. Reducing is the process of just putting out less waste. An example is, companies using less plastic when wrapping their products. Reusing is finding a new use for a product that is supposedly trash or using something more then once. An example of reuse is using washable cups or travel mugs instead of disposable cups. Recycling is converting waste in to reusable products. An example of this is recycling used paper into new paper. Upcycling is reusing materials in such a way as to create a product of higher quality or value than the original. The difference between Upcycling and recycling is the fact that recycled material is generally degraded or broken down to use for making a new product, while Upcycling uses the products in there as is form to create new pliable products.
    • Pocket-Sized Contest
    • Science of Cooking
      Science of Cooking
    • Pro Tips Challenge
      Pro Tips Challenge
    thanks for sharing! do you have more photos to accompany this Instructable?
