Introduction: Upcycled Pouch Using Mixed Discarded Material
Picture of  Upcycled Pouch Using Mixed Discarded Material
An easy and fast project using discarded banners and felt to make pretty pouches. It can be used for your everyday needs, or even a perfect gift for a special someone!
At Biji-biji, we aim to help ourselves by taking care of our environment. You can use upcycled materials or any used old cloth / fabric to make this pouch. By doing this, you can support and sustain a healthy environment for us and the next generations of millennials.
If you like this piece, do check out more of our sustainable fashion products!
What you need for this project:
Measuring tape
Marking chalk
Ink marker
Scissors
Cutter
Nylon thread
Ruler
Discarded banner
Felt
Zipper
Sewing machine
Step 1: Making Patterns
Picture of Making Patterns
You need to make 2 patterns for this pouch
Firstly for the banner, you need to :
  • Draw a rectangular with width of 8 inch and length of inch
As for Felt, you need to :
  • Draw a rectangular with width of 8 inch and length of 2 inch
You need to place a 1 cm seam allowance around both patterns and make sure you leave a mark for each seam allowance (refer to image)
Step 2: Cutting the Pieces
Picture of Cutting the Pieces
Trace the small panel on felt and cut 2 pieces.
Trace the big panel on banner and cut 2 pieces.
Make sure to trace back all the markings and make tiny cuts on them to indicate the position on fabric once you cut the panels.
Step 3: Sewing the Zipper
Picture of Sewing the Zipper
Take the banner panel and fold down the 1cm seam allowance on the width of it.
prepare your zipper before placing the folded edge right next to the zipper teeth and secure it with pins.
sew on the banner and try to keep you stitching as close as possible to the edge of the panel. ( refer to image )
Do the same for the other banner panel.
Step 4: Sewing the Felt Panel
Picture of Sewing the Felt Panel
Take the felt panels and sew it on to the banner pieces.
Fold the seam towards the banner.
Place the pouch facing you and stitch on top of the seam with width of 0.5cm ( refer to image ).
Do the same for the other side.
Step 5: Sewing the Sides and the Box Corners
Picture of Sewing the Sides and the Box Corners
Now set the panels on top of each other and make sure the wrong side of the pouch is facing you.
Sew from one side to the other. Make sure the zipper is opened enough for you to put your hand in.
After sewing, hold the corners of the pouch with both hands and make the triangle to shape the box corners. ( you can refer to the pictures and video for a clearer guide.)
Step 6: Finished Product
Picture of Finished Product
Turn the pouch inside out and make sure you have everything done. The pouch should be able to stand on the table on its own.
Well done! you have finished all the steps and you can enjoy your new upcycled pouch.
Simple and quick to make, and it sure looks good too.
Do check out our other collections of designer bags made from discarded materials, like seat belts and felt (from carpets).
About This Instructable
406views
10favorites
License:
Bio: A social enterprise whose design core is open sourced and inclusive.
More by bijibiji:Motion Sensor Light Upcycled Fabric Pouch Upcycled Pouch Using Mixed Discarded Material
Add instructable to:
