Introduction: Upcycled Rattan Edison Lamp
Picture of Upcycled Rattan Edison Lamp
Being someone who likes lamps, but not something that shop bought, something thats "different".
Having a new shop opening in the town where I live, which has everything I need, that being off the wall items, which when looked at from a non standard angle can be re-used and upcycled.
The lamp that I saw while looking around was meant for a candle, which when I looked at it I thought would look nice, but had room for improvement.
Step 1: Bill of Materials
Picture of Bill of Materials
Rattan Lamp - Sold in The Range £6
Inline 3 pole switch - E-Bay, £2
Bulb Holder, I went for an antique look, as I felt the bright Brass would look wrong.
Bulb, there are a few type of these bulbs commonly known as Edison Bulbs, but as you know, Edison invested the long life bulb, the reason for the name is the similarity between the bulb he created in the late 1800's, rather that the normal incandesant bulb now commonly seen.
The bulb can vary in size, and shape, I have used a 40w, "Squirrel Cage" Bulb for this as I like the effect.
Step 2: Putting It Together, Electrics
Picture of Putting It Together, Electrics
Remember, this is main electric, it kills. If you do not know what you are doing, please, do not do it, find someone who does and can help.
I used 3 core fabric covers wire of an appropriate size for the load, I used 3 core for earthing purposes.
First, I wired the buld holder,
Second measured 1meter, and installed the Inline Switch,
Third, I wired the 3 pin plug, ensuring again, I used the correct rating fure, in this case, 3amp.
To calculate the correct rating fuse, use teh following formulae :
I (Amps) = P (Watts) ÷ V (Voltage)
40 / 240 = 0.16
The smallest fuse available is 3amps.
Step 3: Mounting the Bulb Holder
Picture of Mounting the Bulb Holder
In this example I have used bright green cable ties so they could be seen easily, I will replace with with black.
Also, please note that there is an extra cable tie to act as a cable strain device, this is to help should someone accidently trip or pull on the wire and prevent the live wires being pulled out of the buld holder.
Step 4: The Finished Product
Picture of The Finished Product
Now, put it somewhere nice and enjoy the satifaction that upcycling gives.
Enjoy
KerryW (author)2015-08-10
Awesome :-) I love this, so creative
sparks_vfr (author)KerryW2015-08-10
Thank you KerryW
CLullham (author)2015-08-12
This is a beautiful project. Perfect for a small yard, just to add a little touch to it. And the light is warm which is always nice.
sparks_vfr (author)CLullham2015-08-12
Thanks very much, however, it's not waterproof/splashproof/shgowerproof in any way.
I do like the light they give off, much warmer than a standard incandescent bulb
About This Instructable
1,134views
39favorites
License:
More by sparks_vfr:Binary Clock Using NeopixelsInfinity Mirror with Interchangeable LogoHot Glue Trinkets
Add instructable to:
