Upcycling a LCD Into a Illuminated Photo Frame
Introduction: Upcycling a LCD Into a Illuminated Photo Frame
We all might have come across this, Broken and Thrown away Monitors and Laptop LCD's, well they can be recycled and re-purposed into cool stuffs, In this Instructable, I'm gonna show you how to turn a old LCD monitor into a illuminated Photo Frame.
Step 1: Gathering the Parts
Things You will be needing:
An old LCD monitor - While walking around I found this monitor over the trash, I took it home.
(The Reason I'm using this is because the Back light is CCFL, which has small quantity of mercury, I don't want that to pollute the environment,upon examination I found that it had 4 CCFL tubes and there was Screen Leakage)
LCD Inverter (In my case the Power Supply Board was Dead, so had to make this Purchase)
LM7805 - 1nos(5V Regulator)
DC socket
Some Laptop Power Supply( I had a 12V, 3A supply around)
Screw Drivers
Miniature Push Switch
Prototyping Board
Soldering Iron
Anything you want to make a sturdy support
A nice Scenic Picture
Step 2: Dismantle and Tinkering
Start to unscrew and open up the LCD, Here is the Power Supply board, which couldn't power up.
We wont be needing the LCD panel, the black glass that shows the Images. So remove that too, All we need is the White Surface with the Lights.
So I soldered the components according to the schematic diagram.
Step 3: Resplendent
The next important thing is the final finish, Cut and Fold the image so it looks like perfect.
Use some instant glue and paste the image.
For the support I'm using the back plate of the monitor itself, with a piece of acrylic sheet so it could sit on my table.
and Voila! Check out the Pics.
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    • Paper Contest 2018
      Paper Contest 2018
    Would be great, keep the lighting side downwards and add some iridescent film :), if possible add brightness control with proximity sensor.
