3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Updated Bicycle mounted steadicam
Step 10Road test
Here's a short clip of video from a weekend ride where i used the Steadicam mount. The new design seems to have made a big difference for the basic road conditions.
7 comments
Oct 18, 2007. 9:07 AMPapa G says:
This is great. I can see huge improvements over the last version. I would love to see footage of this mounted on the frame rather than the handle bar. I think that'll make it near perfect as the handle bar wiggles a lot to keep the balance of the bicycle.
Sep 29, 2009. 10:27 AMdewexdewex says:
I'm using a digi stills camera, which shoots 1024/768 movies, fixed to a front mounted bag on a Brompton folding bike. I have no damping and it's not good on rough surfaces, but there is an advantage, as the bag it's fixed to is on the frame and not the handlebar. If you search dewexdewex berlin on youtube, you'll find an example of it in use. I'd like to build some simple steadying device as well, and I was thinking of incorporating the simple pendulum type steadicam with the central pivot constrained to limit yaw (vertical axis) and parrtially constrained with rubber to limit pitch (horiz left to right axis), so the cam would always shoot level,. I'm thinking that the joint could be inside a vertical helical spring running in a circumferentially tightenable shroud for damping with friction.
Dec 10, 2009. 9:06 AMdewexdewex says:
Hey,
I had a look at your pendulum version, and, as I understand it, you were just letting the camera be a pendulum weight swinging from a pivot with no counterbalance. I think this would have worked better if you'd have tried the following:
Put the camera at the top of a vertical beam, put a counter weight at the bottom of the beam, make a pivot somewhere in the middle of the beam with an axis parallel to the camera shooting axis, and set up the balance between the weight and the camera, so the weight provides a marginally greater moment than the camera.
This is basically how the steadicam junior devices work, except they have a ball joint instead of a single axis one.
I'm guessing the main vibration problem with the mount is going to be along the vertical axis, and the others won't contribute much to the problem. I might test this thinking with an iphone or ipod touch strapped to my bike, as they have 3 axis live plots from the accelerometer to watch as I ride.
Basically, what I'm going to do with my scratchy thinking is build a mount like your first one with a damped/sprung unit (either like yours, or a more basic vertically mounted spring damper from an RC truck), and fix a counterballanced pendulum to this, which allows the camera to come to equilibrium pointing forward and level.
Let me know if you think this sounds more reasonable than my first ramblings.
Dave.
Aug 12, 2009. 4:03 PMgenenewyork says:
Is there a newer version that you made? This is a really nice idea.. I am dying to see more footage or try making this device myself. But I have problems with patience though. Can you email me please. genenazarov@gmail.com
Jan 9, 2008. 5:53 AMconradjacob says:
The use of strap hinges is absolutely brilliant. I built one section and it worked great on / in cars. I used a bungy cord through double pulleys instead of a spring. My theory is that it is important to balance the rig as close to horizontal as possible and the bungy is easily adjusted. The doubling was so the bungy isn't near it's limit, maximizing float. On a bike I found lateral vibration/movement is still a problem. I am going to try simply hinging the rig so it can swing a bit side to side (going to be hard to control). I didn't use Stanley hinges - this could be exaggerating my issues.
Jan 13, 2009. 8:29 PMjasdipBOY says:
Do you think you could post some images of your bungy/pully design? I'm about ready to build this and wandering if I should go your route. Thanks!
Jan 14, 2009. 5:45 AMconradjacob says:
I am away from my stead-thing and will be for a month. I'll post then. I did add a second hinged arm for side to side float. Made it all pretty ungainly and only able to balance an HV20 weight camera. Even though it has been a year, I haven't tried it on a bike yet.
Oct 26, 2008. 7:24 AMzzpza says:
very impressive work :D
Nov 26, 2007. 1:52 PMflee2010 says:
Yes much better bump absorption. Looking for something like this to be used on bikes and in car setups. Nice.
Aug 7, 2007. 2:58 AMtheking says:
iloveyourvids
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
12
Author:fireballxl5(In the bike lane)
I've always been a maker, mod-er, and tinkerer. I started out by taking things apart and then trying to put them back together.
