Upgrade Your Old Ceiling Fan by tinawina
Cheap fans with phony shiny wood grain and "brass" parts are pretty ugly, and pretty prevalent. Since I couldn't find a great looking replacement that didn't cost a gazillion dollars, and since my fans still worked fine, I decided to just change their look. This project is easy to do and doesn't require any electrical work (unless you want it to). Plan on taking 2-3 hours to tackle the first 6 steps, and another 30 mins to reassemble your fan and turn it on.
Step 1: Materials
Primer paint
Finish paint
Rustoleum oil based paint or the like
2-3 paint brushes
All purpose cleaner and towels
Screwdriver (flat and/or Phillips depending on your fan)
Ladder
Step 2: Remove fan blades from motor
I have done two fans. For the first I removed the entire fan from the ceiling requiring me to turn off the power to the fan at the circuit box. While this did allow me to fix a problem with the fan (it's a 3-speed but was only one was working), it made painting the motor housing difficult.
For the second fan I just left the motor on the ceiling. This made painting the motor housing really simple. Removing the fan blades is very easy to do. Seems pretty standard that the blades are attached to the motor by a couple of screws and that's it. Just remove the screws and the blade and connector will separate from the housing.
Step 3: Separate fan blades from connectors and clean all
Unscrew the blades from the connectors. These screws came out very easily in both my fan projects.
Fan blades get super grimy and dusty, esp if near a kitchen which was the case for one of mine. I used all purpose cleaner and rags and went over the blades a few times to get them clean. Same with the connectors.
Step 4: Put a primer coat on the blades
You only have to paint one side of the blades since no one will ever see the top side. Prime the edges of the blades first and then work a thick coat onto the face of the blade. Any good quality primer will work. I used Zinsser water-based primer.
I did one coat of primer and that seemed to be enough. But two coats wouldn't hurt, and primer paint dries pretty quickly.
Step 5: Paint metal parts - no primer needed
I used Rustoleum oil-based black satin paint. If you use an oil-based paint wear gloves as the paint likes to stick around. For the connectors I did a nice thick coat with a cheap brush. Even if you splat it on, the paint sorta smooths itself out as it dries and has a spray-paint finish to it in the end, very smooth and even. One coat was all I did, with a little touching up on the finished product. For the motor housing, I positioned a 6-foot ladder on one side of the housing attached to the ceiling and painted one half then moved to the other side to paint the second half. I used a much thinner coat on the housing since I didn't want drips -- that Rustoleum is nasty stuff to clean up.
Step 6: Paint blades with two coats of finish color
By now the primer coat is dry enough to do the first color coat. I used left-over water-based latex paint from the paint job recently done in my living room so that the fan blades match my walls. You'll need to do at least two coats if you are going to a lighter color on your fan blades.
Step 7: Reconnect blades to connectors, and connectors to motor
Wait overnight for everything to dry and then put the fan blades and connectors back together -- reverse what you did in steps 3 and 2. Be careful when handling the connectors because the paint can scratch off pretty easily. Not really a problem later since you will probably never touch the connectors, or if you do it will be with a soft cloth when cleaning.
My fans have two rows of screw holes so that I can choose to use four blades (inner row of holes) or five blades (outer row of holes). I went with four to minimize the fan even more. With the nice white paint you can hardly see the fan when it's on.
Step 8: Touch up et voila!
You may need to touch up your paint job, especially the paint you use on the connectors and motor housing -- it's tough to paint those shiny surfaces thoroughly in one go around. Regardless, I found touch-up to be minimal.
I chose to ditch the horrible glass globes that come with these old crappy fans and invested in these Satco light adaptors. They work like adjustable track lights. I picked these up online for around $12 each, so $72 for enough for the two fans. (I bet you could do something awesome and super cheap with little Ikea light fixtures!) And the six 50w halogen narrow floodlights set me back about $30. But even with these accessory costs, I got two great looking, great working fans for well less than half the cost of one replacement fan.
artcobain says: Apr 21, 2010. 8:06 PM
 what does it looks like at night?
tinawina (author) says: Apr 22, 2010. 6:41 AM
 it looks great at night. Replacing the old glass "shades" with the new adjustable spotlights gives a much better room light. And being able to position the lights -- on the wall, on the floor, on the dining room table... -- makes the fan a lot more functional. There's really know flicker at all. I have two of these fans in my living room/dining room -- large room -- and they really look great. No regrets having done this project!
ac1D says: Mar 4, 2010. 1:55 AM
You forgot some step:
1) Add some knive to each blade
2) mount it on your truck
3) hope zombie come!
tinawina (author) says: Mar 4, 2010. 7:51 AM
 Ha! You should def pursue that version and post it to Instructables.
davidhullster says: Mar 3, 2010. 9:25 PM
Why does the fan have 4 blades before you painted it, and 5 blades after?
tinawina (author) says: Mar 4, 2010. 7:47 AM
 I think my intro page is a bit confusing - sorry! My fan started out as a 5-blade fan that is brown faux wood and faux brass. On the intro page there is a picture of it -- scroll down to just under the big photo of the finished 4-blade fan and click on the thumbnail to see the original.
I wanted to minimize the fan as much as possible. Since my fans offer the option to use only 4 blades or to use the full set of 5, I opted to switch from the original 5-blade format to the 4-blade format in the finished project. I do not notice any difference in air circulation with the 4-blade format.
HarveyH44 says: Mar 4, 2010. 1:26 AM
Just a guess, maybe forgot the 'before' picture after starting the project..  I've got 3 different ceiling fans in my house.  I don't do a lot of planning or fore-thought before jumping into a project, and usually afterward thinking I should have taken some pictures.  Documentation has never been a strong point for me, but plan on doing an Instructable sometime.
tinawina (author) says: Mar 4, 2010. 7:48 AM
 Hi there - there is a "before" picture available. On the intro page, scroll down to just under the big photo of the finished fan and there's a thumbnail you can click that will pull up the photo of the original fan.
I agree about documentation. I realized after finishing the first of two fans that I should have documented. So glad I had a second fan project to do - though I didn't start documenting that one until I was pretty much done. Whoops!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
