(I ran my iPod continuously for over 20 hours on one charge!).
You will also get enhanced shock-resistance! Thousands of iPods have died an early death because they were dropped and their hard drives were damaged as a result.
So, if you have an iPod Mini with a bad hard drive or just want to hotrod your existing unit this Instructable is for you.
Remove these ads by
Signing UpStep 1Materials & Tools
Small Phillips Driver
Small Flat Screw Driver
Plastic iPod Opener Tool (optional)
Popsicle stick or other flat wooden stick
Hot Glue Gun
Xacto Knife or Razor Blade
Fully ATA compatible Compact Flash Card (2Gb min)
2nd Generation iPod Mini. If you use an iPod with a bad drive, just make sure that the unit is otherwise fully functional.
I hear the adapter makes a difference .. what adapter would you recommend ??
Can you recover a 20gb ipod classic with this trick?
Frank
I actually found the iPod in the ditch while working in the field one day. it appeared someone tossed it out their window after it no longer functioned, due the the dead drive. After borrowing a power cord and a quick search of the error that was popping up. I figured out that the hard drive was bad. I found a site that similar to this one that explained how to replace the micro drive with a CF card. I happened to have a 1 gig laying around and tried it. The iPod worked great so a quick order on Newegg of a 32 gig CF card for $60 and a $12 power cord from radio shack and I was in business with a 30 gig iPod for only $72. Way cheaper than any 30 gig MP3 player on the market and it had no moving parts. Definitely couldn't complain.
i just got a free hot pink ipod (lol) so im looking to upgrade and paint it
I took a gamble with the Kingston CF, and read all about how ATA was automatically added to all CF cards prior to adding accelerators. I also looked at the Dane-Elec 8GB that Wallmart sells but you need to order it online and have it delivered to your nearest store. They don't carry the card. I checked Dane-Elec's site and it is an ATA compatible card. Not bad for $20 bucks. BTW, I used my Nano Mini's cord to connect the 2nd gen iPod Mini, my iPhone cord would not work for me.
Thank you for the instructions once again.
i.am.luke08@gmail.com
Thanks,
http://www.amazon.com/Maxell-Compact-Flash-Memory-504001/dp/B002O0KT3C
Like other people here, I'm getting the folder/exclamation point icon on the screen every time it boots up, quickly followed by the "Do not disconnect" screen. Is this because I'm using the wrong type of CF card? If so, which CF cards nowadays will work on an iPod mini? I'm just looking for a 4GB card. Thanks!
Try using a Transcend or Sandisk card.
Cheers
Oops - actually I let it charge awhile and it was recognized in iTunes! It works with this set up!
I'm using OS X 10.6.6 w/ iTunes 10.1.2 (17) on a 2006 iMac 2Ghz Intel Core Duo 20".
I also reset the iPod a few times, too many to know when it may or may not have had an effect.
The entire 16 GB shows up in iPod screen on iTunes. No issues with playback, no issues with uploading - works like it's brand new.
