3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Upgrade the Zen Micro: 5gb to 8gb on the cheap
Step 8Remove the Hard Drive
End of the disassembly road, right here: remove the hard drive.
First, stick the flat-head screwdriver under one of the upper corners of the drive (which would be one of the lower corners of the player) and lever the screwdriver against the case, and the drive should pop right out. Do the same on the other corner to complete the job.
Gently pull the connector from the drive. You are trying very hard not to break the ribbon connector, which can be fragile and easily broken.
When you're done, check and make sure you have everything you need to re-assemble the player. If so, pat yourself on the back. You're ready to upgrade.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
10
Author:technosapien
I am a graphic art hobbyist, web cartoonist, and wannabe electronics hobbyist. Other hobbies: cooking, baking, exercise, computers, video games, trivia, and some more I'm probably not remembering.
