3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Upgrade your Casio fx-82es into 115es/991es/570es
The circuits of Casio fx-*es series are almost the same, except the mode selection part.  So you can upgrade your calculator by modifying the circuit.
I am Chinese and I edited these photos for a local forum. So please ignore Chinese characters on the photos.
This method is available for casio fx-*es calculators. NOT MS or ES PLUS series.
Step 1If you are lucky
Check the version of your calc.
The version is marked on the back of the calc. you can see a letter in a small circle which is at the top-right corner of the rectangle that has text in it.
If the letter is A, you are lucky.
Just open the calc, find the P4 jumper on board, fill the gap with pencil.
Then turn on your calc, see if there are 8 modes available.
If the letter is B, see the following, it is difficult to upgrade, but it is possible.
CAUTION: The success rate seems be VERY low. About only 20% can do it without experience. It is easier to do it with a magnifier.
It will mostly affect the display(too dim, strengthen ) if you fail.
or just not able to turn on.
TRY THIS AT YOUR OWN RISK
17 comments
Nov 15, 2011. 7:41 AMSqueazer says:
I just wanted to mention i have the fx-82ES with the A motherboard and the jumpers are labelled with D not P. And when i "jump" D4_1 it works. Thanks for the tutorial!
Mar 28, 2010. 2:52 PMlemonie says:
Could you explain exactly what this is doing?
It seems to be advising a graphite-bridge on the CPU, which you locate with a ruler... I'm struggling to get my head around this working.
L
Mar 29, 2010. 3:28 PMlemonie says:
So they cost almost exactly the same amount of money to produce, but they add a "jumper" for the more advanced device?
Could you put a difficulty level on this, that is % probability that the average person will break the machine vs enable the modes - it looks risky for someone other than yourself who is obviously skilled and knowledgeable.
L
Jun 17, 2011. 11:37 AMxc1024 says:
Sounds like the stories back from the 70s and 80s when some mainframes could be easily upgraded by doing a simple change such as cutting a wire or pulling out a jumper. People paid piles of cash to have the manufacturer serviceman do it.
Jun 18, 2011. 6:17 PMlemonie says:
Cutting a wire or pulling out a jumper seems an awful lot easier than this...
L
Mar 30, 2010. 3:05 PMlemonie says:
Well done then. You've given me the level of difficulty I had expected.
Thanks again
L
Apr 25, 2011. 9:18 AMsnawaz says:
hi i have a 82 es and im trying hard to convert it to a 911es..after digging the trace i dont know what to do?where is the P* pin?please help.
Oct 25, 2010. 1:23 AMjesux7 says:
hi mmm,, i did all as you said,, but when im gonna use it it doesn't do anything,, would you can help me whit this problem?? i really need the calculator ... i hope you can
Jun 16, 2010. 4:07 AMzhs490770 says:
I'm one of the administrators from Fx-ES(MS) calculator forum,too. English version of the article in the photos are small. If you prefer, you can look to the Chinese forum. Welcome ~ (Chinese forum address:http://fxesms.5d6d.com/thread-2820-1-1.html) Another word of warning: most frequently upgrade is P-mode. Good luck
Jun 15, 2010. 7:46 AMbruce55 says:
I'm one of the administrators from Fx-ES(MS) calculator forum. This guide is only for Ver.B ROM 18 ES Series. This is called hardware upgrade(maybe hardware modify? I'm not sure...) in our forum and "l9" in Chinese. The ES series are easily divided into 82ES, 991ES and other models by a jumper. This jumper were easy to modify in the past few years. (Can you see C(Canceled?)P0, CP1, CP2 and other contacts on the PCB of your ES(Ver.B)? They were connected with the CPU in Ver.A. You could change the P-value(P means program) in the self-check screen by connecting these unconnected contacts.) If you have a Ver.A 82ES and it's ROM 18, you can upgrade it in an easier way with no danger. ROM 21 ES calculators have no 991ES programs inside. So it's impossible to upgrade ROM21 calculators (software/hardware). We have been looking for a better way to hardware upgrade for a long time. But the probability of success is still very low. My old Ver.B ES was nearly damaged many months ago. Luckily, I found a Ver.A and bought it. I successfully modified it into P0(991ES). Now I use Nspire CAS... P0---991ES Fraction format: d/c P4---991ES Fraction format:a b/c P3---82ES Fraction format:d/c P7---82ES Fraction format:a b/c ... P? means more than one P contacts are connected. Modes in menu are depend on contacts you connect P- means no P contacts are connected. It's a very special mode. Modes:3 Output format:decimal Keyboard mode:991ES(That means you can use 991ES' programs which are in Comp mode) There is a complete chart about P modes on our forum but I can't find it now. Sorry. If I find it, I'll translate it into English and send it to this forum. Sorry for my bad English :p
Jun 15, 2010. 7:48 AMbruce55 says:
Why did the format turn into a mess...
Mar 29, 2010. 11:10 PMsantiagopoli says:
 Can you be more specific? I don't understand steps 2 and 3. By the way, thanks for posting this tutorial.
Mar 30, 2010. 3:08 PMlemonie says:
There's a blob of black resin covering the CPU. He's describing how to pick off the black-stuff to expose connections on the CPU. If you bridge these with (conductive) graphite successfully, it changes the way the machine functions.
L
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:urill
A Chinglish user :-(
