Upgrade your original 1984 Macintosh to run OS X Snow Leopard.
Step 2Take apart your suspect.
Next we need to take apart our computer to get at the insides. This differs from one model to another. These original computers were made very easy to take apart.
Most of the time you need a long allen key/allen wrench/Hex key in order to reach all the screws on the rear.
The main concern here is the CRT. When disassembling anything with a CRT you have to be very careful in regards to two things.
ELECTRIC SHOCK HAZARD
The best solution here is first, to leave the computer turned off for a month or so, most charge will have been lost over this time.
Once that is done, you can either carefully grab all the internals without unplugging anything, dump it in a box and forget about it, or you can discharge the CRT (which we do use later for creating the new screen.
In order to discharge the CRT you need a long screwdriver, a resister, and some wire.
  • First, solder up a small circuit with a crocodile clip either end, and a 1-10 Meg resister in the middle
  • Attach one end of the circuit to a screwdriver
  • Connect the other end to an earth point, (i attached it to the metal frame of the macintosh which had since been disconnected from the internals but could be earthed through the power cable, the wall socket does not need to be turned on)
  • Carefully slide the screwdriver under the cap on the side of the CRT with one hand, put the other hand in your pocket, this way if you do get shocked it should hopefully miss your heart and head for the earth.
  • You might hear a small pop, but I did not hear one, personally a small pop would be best as it shows that you have succeeded, Instead I just stood there hoping it had worked.
  • Hold the screwdriver against the contact of the CRT for a few minutes
I recommend this guide, which shows how to discharge the CRT.
Pop the CRT to one side, and pack the rest of the innards somewhere safe incase we need any of it.
GLASS/VACUUM HAZARD
The vacuum tube could explode when put under pressure or dropped. Take care whenever handling the CRT. If you do happen to drop it, put some shoes on, go buy a Dyson, and vacuum everything..
Be sure to keep the original screws, we use these throughout to add in the new internals.
2 comments
Mar 14, 2010. 10:26 AMmman1506 says:
 a 3mm flat head screwdriver works also
Mar 11, 2010. 10:44 AMbobrk says:
 Those are Torx bolts, not allens, at least they were on my 128k and SE/30 machines.
Mar 11, 2010. 2:45 PMb2j2 says:
Those are Torx screws, but an Allen wrench will work.
(Apple dealer in 1984)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
561
Author:gmjhowe(Instructables Chatroom)
I work as a Graphic Designer/Artworker, my time is spent creating a miz of Cyberpunk and Tech related creations for your viewing pleasure. If you have any questions, you can normally find me in the ...
more »
