3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Upgraded Garden-Variety Solar Night Light
Here's something quick and easy that you can whip up in less than an hour, using parts that you may already have lying around. It makes a neat gift for friends and family!
Yes, I'm sure you've seen a zillion solar garden lights stuffed in a mason jar before, and this one is certainly similar. I've changed a few things this time around though, that boost performance and change the look a little. The performance-altering steps are not necessary of course, but they will help the LED stay lit for much longer.
Here's what you'll need:
A dirt-cheap solar garden light - I bought the one I used for a dollar.
A mason jar or some other container with a transparent lid.
A decent solar cell - it should fit inside the lid of the jar. 4V at 80mA is perfect.
One 2xAAA battery holder with leads
Two AAA NiMH batteries
A few bags of small, clear marbles - Cateyes or spiders look best.
And just a few basic tools:
A soldering iron
A glue gun
Step 1Disassemble the Garden Light
If you're not planning to upgrade your garden light, then you can skip ahead to the assembly steps. Just take apart the garden light until you're left with a solar cell, the LED and the circuitry, which should all still be functioning.
If you're going to be upgrading, then read on! Continue taking apart your solar light until you're left with nothing but the bare circuit board. In my case, it was a tiny sliver of PCB with some battery terminals and an LED sticking out. Pretty basic, eh? This little board basically contains a Joule Thief, all neatly mounted and ready to use. Not bad for a dollar - and in many cases cheaper than making your own.
But we're not done yet! Oh no! Get out your soldering iron and remove the battery tabs from the board, they will not be needed. If you want to change the colour of the LED (which I do not recommend in this case, because white looks best), then go ahead and do it now. Be sure to observe polarity.
11 comments
Sep 26, 2009. 4:28 AMdeckchair says:
(removed by author or community request)
Sep 26, 2009. 8:11 PMdeckchair says:
yep thanks got a better light and all is good
Dec 23, 2008. 12:56 PMcanida says:
Looks good, but the marbles might be a little dark. Maybe use half colored/swirly marbles and half clears?
Apr 18, 2009. 11:33 PMfreelunch says:
I loved the marbles too, but also wanted to let a little more light through. I cut the bottom off a plastic water bottle so that it was as tall as the inside of my jar. This left just enough room between the outside of the water bottle bottom and the inside of the jar for a single layer of marbles--the tiniest marbles I could find at my dollar store. Then I made a little cone out of reflective Mylar (aluminum foil would probably work) and placed it in the bottom of the water bottle part. The LED shines down onto the cone which bounces it out through all the marbles. Trying it this way would definitely be too bright for a bedroom night light. But it's still dim enough to be a pleasant ambient light for just about anywhere else.
Apr 21, 2009. 9:46 PMfreelunch says:
Thanks! The mod was mostly necessary because I was using an ultra cheap, ultra weak garden light for mine. I have a little terrace garden (crates strapped to the rail). I already had a couple of jars filled with marbels amongst my potted plants--I thought they made pretty sun catchers. Now, thanks to your Instructable, it looks just as pretty at night.
Dec 23, 2008. 6:29 PMChrysN says:
It's so pretty, great idea!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
347
Author:jeff-o
By day, Jeff is an electronics technologist at a large aeronautics corporation. By night, a mad scientist / hacker / artist / industrial designer wannabe!
