loading
Step 17: Prepare a drop of thread locker
If not used, over time you'll start loosing screws from the bottom of your computer. Thread locker can be purchased at any hardware store. Put a drop of it anywhere on the cardboard and dip the very tip of every screw before you put it in.
<p>Thanks, the tutorial was easy to follow and included some good tips.</p>
<p>Thank you for this tutorial ! The ram insertion is tricky, but everything worked out fine.</p>
Will this affect any saved files in anyway? I'm a little lost as to the difference between the RAM and the Hard Drive. Both memory- but yeah just lost. All I know is my Mac needs a boost
<p>This will not affect your saved files. RAM is just temporary storage, and it's erased every time you turn your computer off.</p><p>You should know, however, that if you have a MacBook Pro w/ Retina, it is no longer possible to perform a RAM upgrade, as the RAM is now soldered in place. If you have a non-Retina, it should still be possible.</p>
<p>I see in other instructions online to disconnect the battery. What is your thoughts on that?</p>
<p>As long as you properly shut down the computer, you should be safe with battery plugged in. If you still want to unplug the battery, be sure not damage the battery connector -- it's kinda fragile.</p>
<p>Be sure to use removable thread locker, not the permanent type!</p>
Hi Doctor Jazz, what is it you're plugging you anti-static wrist band into? I have a band but nothing to attach it to in my work area and something like that could be very useful.
<p>There's a slot for it on the mat (the black plastic thing on the corner; need to remove the alligator clip first). If you're not using a mat, you can also clip the wrist band to the chassis (the metal case) of the computer (in which case leave the alligator clip on). The anti-static mat is the better way to go, though. All mats should have a place to plug wrist bands in on one of the corners. If you live in a dry area, use a water-based lotion on your wrist first to increase the electrical contact with your skin. Hope this helps.</p>
Great, well done Instructable. Clear,concise, well illustrated- couldn't have been done better! Thank you.
Great instructable, thanks!
Thanks, I'm glad you liked it!
About This Instructable
533,749views
59favorites
License:
More by Doctor Jazz:Replace auxiliary thermostat in BMW E34 Replace air intake rubber boot on BMW M50 engines (E34) Weather-proofing your DSLR camera for cheap.
Add instructable to:
