Upgrading Old Multimeter With Buzzer
1,174
6
4
Posted
Introduction: Upgrading Old Multimeter With Buzzer
I have been using this multimeter since I know about electronics. I think that it is manifactured in 1974 so I am 1 year older than my multimeter. It is a durable tool and i decided to upgrade it with buzer circuit.
Step 1: Step: 1 I Found Buzzer Circuit on Net and Used It.
Part list for buzzer:
1. buzzer
2. led diode
3. transistor BC547B
4. resistor 220 ohm
5. resistor 330 ohm
6. resistor 1M ohm
7. switch
8. 3v battery, I used multimeter battery.
Step 2: Step 2: Dismount and Clean Inside
I dismounted it and cleaned all the contacts.
Step 3: Step 3: Placing New Circuit Inside
After cleaning I drilled holes for connectors for probes. Because there wasn't enough space for connectors I moved the fuse into fuse holder and use empty space for battery, where I put buzzer too.
Step 4: Step 4: Replacing Probe Connector
Old probe connector was broken and I replaced it.
Step 5: Step 4: Testing the Multimeter
Final tests.
And we are good to go.
Step 6:
    • Microcontroller Contest
    • Spotless Contest
      Spotless Contest
    • Science of Cooking
      Science of Cooking
    4 Comments
    What makes the buzzer sound?
    The grey buzzer that you can see on picture on step 3, if that is your question. Or oscillation from the transistor when you connect the probes, as it is explained on schematics on step 1.
    By, "what makes the buzzer sound", I was trying to ask what condition caused the buzzer to sound? It is something that you may think you've explained, but you did not. You still really have not clearly either. Although right now I am assuming you mean when the probes have continuity to each other. Because, "connect the probes", usually means hook the probes up to equipment. As in plug the probes in.
    Ok maybe our misunderstanding is that English is not my native language. Buzzer circuit is continuity tester, and when you short circuit probes or test continuity on PCB, buzzer makes sound and diode lights up.
