A retail 120GB hard drive for the Xbox 360 cost around 130$. That seems somewhat expensive to me since I can get a 1TB hard drive for that much. I did some searching and finally found an answer I could live with.
A "do it yourself" 120GB Xbox 360 hard drive upgrade for $50!! NO MOD CHIP IS REQUIRED!
DISCLAIMER: Do this mod at your own risk! You could damage your Xbox or your computer. You could lose your data, get banned from Xbox Live, void your warranty, the authorities take you to prison, Steve Balmer will hold you down while Bill Gates spits in your eye, yada, yada... Don't blame me if any of this happens!
Seriously, I did not have much on my hard drive that I would mind losing. This will void the warranty on the hard drive. I just paid for another 13 months of Xbox Live, so I was a little nervous... but I have not been kicked yet!
Some games have content and save games that are media locked. This means that it will not work if it has been moved to another media (new hard drive, memory card, etc.). I have not experienced it yet, but I have heard reports of it from others.
Remove these ads by
Signing UpStep 1Hardware, tools, and software needed
- A PC or laptop with SATA. You cannot use a USB-SATA converter with Hddhackr!
- A floppy disk. If you don't have a drive, you can use an external USB floppy disk drive.
- A USB-to-SATA adapter. You can use this for the Xplorer 360 software.
- Precision tools with Torx bits. I used a T6 and T10 bit.
- Your mitts
Hardware needed:
- Western Digital Scorpio WD1200BEVS 120GB SATA hard drive - Don't try to go with another drive! This one has been reported successful with hundreds of DIY 360 hard drive upgrades all over the net. You can <NO LONGER> buy it from Newegg, but you can get it from PCConnection.com. CLICK HERE TO ORDER FROM PCCONNECTION.COM
Software needed:
- Hddhackr 0.91
- Xplorer360 xtreme 2
- Xplorer360 BETA 6 - Might not be needed. Some people reported success with Xplorer360 xtreme 2. I only used the xtreme 2 version.
- hddss.bin file from a retail 360 120GB hdd - This file contains copyrighted code, so I don't think I can post a link. Use your Google finger to find it.
- Hex Workshop - I recommend you purchase this program, but you can just use the trial for now.
- WinHex - If you have the full version of this, you can skip Hex Workshop. The trial version of WinHex does not allow you to write to hard drives.
- Boot disk image - I used a Windows 98 SE OEM disk image.
Most computers have a key either F11 or F12 to enter the boot menu from which you can select the drive you want to boot from(much simpler than going into BIOS), just check on the start up screen to see which key takes you to the boot menu
http://www.newegg.com/product/product.aspx?item=N82E16839200006
I'm talking about to flash the hard drive, not to simply transfer files.
The site is not very user friendly, and assumes you already understand a LOT that I doubt the average make user does. And, I personally didn't really want to shell out an extra $10 for a usb drive when I'm trying to do a money-saving mod.
You boot from a usb drive changing your computers boot setting in the BIOS menu. When you start up your computer, it should say something along the lines of "F2 to enter startup" (actual key may vary). You press that key, and it will bring you to the BIOS setting screen, which has a key to instruct you on how to cycle through menus and change values.
Cycle through the menus until you find the option to change the order your computer checks the drives to boot from, it is probably currently set to check the optical drive, then hard disk. Instruct it to check the usb ports before the hard drive, and if you've properly configured the usb drive, it will boot from that.
And if you don't want to buy a flash drive, you could just borrow one from somebody.
I followed it and my 360 recognizes my new 120gb BEVT, however, it does not recognize the transferred files from my old HDD.
Stuck it in the 360 to format it, all partitions show, says 107 GB free space. all good.
After I transfer the files over, my 360 says nothing it on it, no savegames, no profiles, no nothing. yet says like 23 gb free of the 107gb...
help? any ideas?
http://www.bestbuy.com/site/Western+Digital+-+Scorpio+Blue+250GB+Internal+Serial+ATA+Hard+Drive+for+Laptops/9024147.p?id=1218012522486&skuId=9024147&st=Western%20Digital%20Caviar%20Blue%20BEVT&cp=1&lp=10
