3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Upgrading the Xbox 360 hard drive CHEAP!
Step 5Switch hard drives
Switch hard drives
Once the hard drive has been flashed, you need to begin formatting it. You can format it using the Xbox 360's built-in format function.
1. Take the old hard drive off of the Xbox 360. Do this by clicking the eject button and popping out the drive.
2. Break out the precision tools and the Torx bits, it's time to void the hard drive warranty.
3. Use the T6 Torx bit to remove the 4 screws on the case. You will have to break the Microsoft sticker to gain access to the last one.
4. Once the screws are out, pull the casing off.
!!!!Be careful not to lose any of the pieces on the inside. There will be a black latch piece, the button, and a spring.
6. Use a T10 Torx bit to remove the screws holding the hard drive in.
7. Pull back the metal piece over the hard drive.
8. Disconnect the SATA and power from the drive.
9. Replace the old drive with the new 120GB hard drive.
!!!!Only use a couple screws to hold everything in place. We will be taking it apart again soon.
10. Place the hard drive back on the Xbox 360.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
31
Author:jwilson27
I am very geeky. I love to do hardware stuff like electronics and robotics projects, as well as software (coding and such). I am a full-time net / sys admin, plus I balance being a manger in there s...
more »
