I had read about the process for this upgrade years ago when I had my Elite 250, this process was taken from the Yahoo Honda Elite 250 Group and the tech tip from Randy Pozzi and Dennis Flora. It seems like you hit a bump and three miles later you are still bouncing along. It seems sensible that putting Honda CB350 shocks on your Honda Elite can be a good choice to improve handling, but the side by side comparison is shocking. The Elite shock looks like it is meant to hold up a hatchback rather than safely keep you on your bike.
Remove these ads by
Signing UpStep 1: Take off body pannels
Take out the screw (under the passenger foot peg)
Finally there is a peg under the passenger handle that just pulls out.
Replacing the screws and bolts where you found them can help keep them straight for reassembly.
Visit Our Store »
Go Pro Today »
My stock bolt from the lower mount of my right-side shock ('85 CH150D) is about 35.25mm long (total length) with a thread length of about 27.75mm.
Also worth mentioning is that you should use a high grade bolt in this application, as two of these will be bearing most of the rider's weight, and that of the bike's rear end.
Randy Pozzi & Dennis Flora's original tech tip is worth a read! Thanks for this Instructable!
http://www.engineeringtoolbox.com/steel-bolts-metric-grades-d_1428.html
and cool instructable, post a pic of your honda side-on with a befor an after so we can see the difrence
