The only place left to grow my veg, that gets any sun, is the patch of wall shown in the photograph.
I wanted to use window boxes in a stepped arrangement so that the higher ones would not cast a shadow on the lower ones.
I also wanted a structure that would take under an hour to build so that I did not lose heart halfway through.
Remove these ads by
Signing UpStep 1Feet.
They did not need to be anywhere as thick as this but it's what I had.
I simply put them against the wall at my desired angle and marked the tops and bottoms parallel to the wall and floor.... and cut them with a bowsaw.
I would add an extra length of timber along under each trough.
Grand idea, though, and kudos on the Fast Show reference.
I was making up the design as I went along and could not believe my luck on finding that the boxes could be supported on just two batons; however I shared your concerns about collapsing.
They were already twisted, but should they fail, I will put a shelf across each baton set and rest them on that. I will put an note to this effect in the instructable.
Thanks.
They must be bigger than they look in the photograph; I had two plants in a pot this size last year and reaped many tomatoes....I did support the stems on plastic netting though.
I'll update this instructable later on in the year.
L
