Upper kitchen cabinet jack
 by sbartlett3
I saw these at this site: http://www.woodworkingtalk.com/f17/cabinet-jack-4053/, and decided to try them out. They are hands-free, all the adjusting can be done with your foot.
Scaffolding jacks, angle brackets, hose clamps, 1 1/2" pipe, plywood and hack saw..  JB Weld and pipe cutter optional.
I didn't end up using the bolts, as I didn't want to drill through galvanized pipe to secure the angle brackets.
If the base cabinets are already installed, or if you prefer to put them in first (because you like to climb on them to do the uppers) then cut smaller sections of pipe to use the jacks on the counter tops.
Doing the uppers first also avoids having to do something to avoid damaging the countertop with the jack base.
heathbar64 says: Aug 1, 2012. 6:22 PM
I've seen these and wanted to buy or make one. Yours seems pretty heavy though, and I wonder if the scaffold feet would cost as much as a commercially available cabinet jack.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
