Upside-Down Hanging Self-Watering Earth-Filled Box!
I've been using DIY versions of a self-watering container with a name similar to "Dirt Box" (or "dearth box") as well as upside-down tomato planters for the past couple years on my concrete, second-story balcony. Here's how I took the basic wicking water principles of a popular patented and trademarked earth-filled box, and applied it to my upside-down hanging tomatoes.
Upside-down planters are cool. The major weak point has always been keeping the plants hydrated, especially during the peak of summer while producing fruit. In the first year, with no special consideration for watering, my plants suffered due to my unwillingness to schlep water to the porch and lift it all the way to the top of each planter. I mean every day?!?! Come on. It was never going to happen.
Last year, I tried drip irrigation. I suspended a tank of water above the level of the top of the upside-down planters and ran a thin hose across the tops of the planters with drip nozzles. The problem was that I could never get the water balanced so the first planter would get the same amount of water as the last. I also had problems getting them to drip slowly enough to last all day. Most of the time, I would be able to keep them hydrated but there was a lot of waste as the the water would run through the plants after an hour or less. Going away for the weekend meant severe drought damage.
I made my own planters in the style of the planters named after a popular planet and marketed by a company with at least one trademark attorney, and that was the best thing to happen to my balcony. I could be relaxed about watering and my vegetable plants thrive. This year, I finally figured out how to give the hanging tomato planters a reservoir without adding weight to the planters and losing dirt volume. After setting up this system, 100% of the water is going into the plants. There is absolutely no run-off waste.
Step 1Overview
Overview
My system has four planters and one reservoir. There is a hose from the reservoir that runs horizontally under the planters. Each planter has a hose at the bottom which is fat enough to contain wick. This hose is connected to the horizontal hose. The wick is about 10 inches long with half of it in the hose and half inside the planter. I made the reservoir out of a 4' long section of 4" diameter PVC pipe. The reservoir should be hung so the lowest point of the reservoir is just barely higher than the lowest point of the wicks. The reservoir should also be shallow enough that the water at its highest level is below the dirt. The water travels freely from the reservoir down the hose and back up into each wick. The wick, using the power of capillary action, takes the water up into the dirt where the plant roots have a party. If you understand this concept, you're 80% done.
My setup is only one example of how this can work. You can use this as a guideline to make 1,000 planters with 20 reservoirs. Go according to the materials you can acquire and what physics will let you get away with. While planning, always be mindful of how much your planters and reservoir will weigh when they are full, how strong the chains are, and the connections that hold them in place. My assumption is that you can figure out how to hang these large, awkward items in a safe way. I will show you how to build the parts for water and dirt.
55 comments
1-40 of 55next »
Aug 12, 2011. 7:53 AMcyndielou says:
my mom has been growing upside down things for yrs and years......way before any topsy turvy stuff came out. she did find out she had to water daily, so she put layers of newspaper and hay or straw like mulch in the top of the bucket to cut that down. there has never been any crop failure. she even had 1 ~5 gallon bucket with tomatoes at the bottom, and sweet potatoes growing from the top. that was interesting as the bucket was filled with taters. that's my 2 cents!
Jun 14, 2011. 10:06 AMadammw_80 says:
My dad and stepmom did something similar, but they reported their plants started Curling up instead of growing down. Did you have an experience with this? Thanks!
May 14, 2011. 2:53 PMdoccat5 says:
I just add a coffee filter with a slit for the root then add the sponge. The dirt stays in and it's super easy to water. The hangers with tomatoes did much better than the one's in the main garden this year. We had very high temps for a very long period of time. Just couldn't get enough water to the one's in the regular garden. But I got enough of the buckets to do some canning. Sure was good in Jan/Feb ^-^.
Apr 4, 2011. 7:10 PMaw76 says:
wow, well done...im really impressed by the setup....i understand why the lowest point of the reservoir needs to be higher than the lowest point of the wick, but i dont understand why the
"The reservoir should also be shallow enough that the water at its highest level is below the dirt. "????
have there been any improvements or problems since u posted this?
awesome job...thanks
Apr 23, 2011. 6:42 PMhspam says:
If the water in the reservoir is above the dirt level then the water will flood the bottom of the planter. This will cause a pool of water in the bottom of the planter and and may cause the roots to rot or the water to flow out the hole the plant is coming out of. The idea is that if the water is only touching the wick then the wick will "wick" up only enough water to keep the soil moist not wet. I hope I make sense.
Nov 1, 2010. 11:17 PMMotta says:
This is just GREAT!
Aug 29, 2010. 6:40 AMcontainer_gardener says:
Awesome!!!!
Aug 24, 2010. 11:27 AMpmartinez says:
Thank you, I've been thinking to do something like this, very professional and nice looking.
Jul 5, 2010. 2:56 PMWickedSpindle says:
Wow this looks amazing, and I love the instructable, very thorough with tons of picture tags. I love it. I think I will make these for the next our next house when we change duty stations! I'm so excited. Thank you!
Jun 28, 2010. 8:08 PMLetsExplodeSomething says:
(removed by author or community request)
Jun 29, 2010. 10:58 AMtrailleadr says:
Even if it is patented, why would I want to go spend money on it when I could have the accomplished feeling of building it myself? (and probably for less than the commercial product)
Jun 29, 2010. 3:51 PMLetsExplodeSomething says:
to support local business and the economy which is in the gutter
Jun 29, 2010. 6:55 PMtrailleadr says:
A valid reason, but not good enough for me to avoiding building it since I already own a majority of the parts listed. What parts I don't have I would buy from the local hardware store. Which while it wouldn't have the same financial impact as a bigger purchase, also supports the economy and local businesses. Thus allowing me to save money and support my family in these hard times until I can find a job. At which point I would be able to better support the economy by purchasing one or two of these, should the need arise. BTW velvel, this is a well done 'ible regardless of it's patent status, and will be very helpful. Thank you for sharing. :)
Jun 29, 2010. 3:52 PMLetsExplodeSomething says:
Is that a question or a confrontation?
Jun 25, 2009. 8:01 AMasiedentopf says:
This is a great project and idea. There is only one problem I see with your containers...they are made of a type of plastic that is NOT UV (Ultra Violet) stabilized and in the sun they will break down and come apart. It may take a summer or 2 but they will. Maybe use Black containers instead. Also, rather that hanging them from those weak handle use a regular plant hanger that cradles the container. Thanks for sharing!!
Apr 30, 2010. 2:59 PMamandakay1 says:
 Are the black versions of this UV stabilized?
Jul 8, 2011. 10:37 AMjwong1 says:
People who properly maintain their boats know: the sun will eat your stuff though you can protect it with a varnish or paint that resists UV light. Local hardware stores sells Marine spar varnishes and paints for less than $16 per quart. One brand even makes their product in a spray can. Paints can make your DIY project look pretty.
If you don't use the whole quart, ensure preservation of the leftovers by pouring into a compressible plastic bottle, squeeze out air and screw tight the cap.
May the tomato be with you.
Apr 17, 2010. 7:35 PMfrogmama says:
I'm planning on making some up-side-down planters this year and really like those waste baskets - but looks like they aren't available anywhere anymore  :(
For those who like the frosted white wastebasket look, though, the Dollar Tree has some similar shaped frosted garbage cans that would probably work, but you'd have to drill holes for the chains.
Apr 4, 2010. 5:47 AMfegundez1 says:
this one rocks, I have had a few problems getting the plants to thrive. For some reason they dont grow as well as the ones I hang rt side up. I will keep trying though as I hate to fail!!
Aug 9, 2009. 4:27 PMblaskos says:
Do you have a total price that this costs. What you did looks awesome and i just want an idea or ball park range so i can figure it out. Im thinking about trying this or doing a hydroponics set up, do you have any suggestions which would produce more fruit for tomatoes? Also, it will be in my basement since its coming to winter time!
Jun 25, 2009. 12:10 PMHobbyistX says:
Its always good to see green instructables, but I have a problem with the current fad of upside-down planting: plants don't like to grow upside-down! Plants are phototropic and gravotropic meaning they make significant effort to grow upwards in response to gravity and illumination. Plants grown upside-down are invariably less healthy than plants grown right-side-up, as they expend considerable energy trying to orient themselves. Show me a photo of an upside-down plant that isn't all twisted up and sickly looking, and I'll show you a photo of a plant that was only just recently turned upside down.
Jun 29, 2009. 10:06 AMstengah says:
I'll second that. In spite of this being all fun and cool - any green project that does not support plants' health is a bit selfcontradictory imo. Anyway - would be nice to see if you (velvel) or others actually have managed to grow a decent healthy harvest with a low failure rate? Personally, I sort of doubt it and If that indeed is not the case - well, then I don't really see the point...
Aug 4, 2009. 6:48 AMpuppylinux says:
Jul 18, 2009. 1:03 PMtreesneedtobehugged says:
best of luck on the get in the garden contest!
Jul 7, 2009. 8:11 PMcrocodialrock says:
Hey. I love this Instructable! I am trying currently to put it together using supplies I am able to collect from work (hospital). The best containers I've found to use have been one liter bottles that I am going to cut the tops off. They have a nice size hole in the bottom that perfectly fits a 60 cc syringe that I am going to use as the "piping". My question is do you think these liter bottles will be large enough to house a tomato plant? I am also going to give this a shot with something a little smaller like a basil or other herb plant
Jun 29, 2009. 2:25 PMJJungJr says:
This is a pretty good plan. I have made my own 'topsy turvy' planters out of 5 gal buckets . . . the plant is put through the large hole in the center, 1" in this instructable. To help keep the plant in the bucket, I took a regular kitchen sponge, any color, and cut it in half. I then cut one of the halves nearly in half again, leaving about a half inch or so connecting the two ends See photo 1. I then used this slit sponge to help support the root ball by placing it against the bottom of the bucket (on the inside) and put the stem in the center see photo 2. It also has the advantage of telling me when the planter is dry by feeling the sponge at the hole. Here are a few pics to help you visualize what I have done. I included my multi planter with green pepper on the left, cilantro in the center, cucumber on the right and tomato on the bottom.
Jun 28, 2009. 11:46 PMdrwarm says:
How does the dirt stay in the basket? ie why doesn't it just fall out the hole in the bottom? Is it because you make a small circle in the foam/gravel etc for the stem of the plant to go through but the rest of the dirt just sits on top? I don't really get why then you have a 1/4" hole (plant hole) for the stem to come through. Sorry it might be really obvious!
Jun 29, 2009. 1:47 PMBig Ugly Mich says:
I've never done this myself, but I'm told you plant your tomatoes in it, care for them for a week or so, then flip the basket over AFTER the root ball forms so the root ball can hold the dirt in the bucket.
Jul 18, 2009. 8:10 AMYotaTruck says:
In his design he puts a PVC pipe "collar" around the hole the plant passes through. So things can't easily get washed out.
Jun 28, 2009. 11:09 AMbuschmeister says:
This looks like a great project...I think i'll be building a few of these!!!
Jun 26, 2009. 5:34 AMhybridracers says:
I kind of wish you had actually did the step on this instructable as you wrote it. I find myself confused with the wick, aeration hole and that stuff. I tried to use some 2 liter bottles but I dont think they work for even small tomato plants, too small of a container. Maybe strawberries though.
1-40 of 55next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
24
Author:velvel(Zev Goldberg)
