Step 3Make the Planters
Do the following for each wastebasket/bucket (hereafter referred to as "the planter"):
- Look at the bottom of the planter.
- Cut a hole for the plant 1" in diameter in the center of the bottom of the planter. (fig. 3a)
- Cut a hole for the wick 3/8" in diameter near the first hole in the bottom of the planter. (fig. 3a)
- Based on other guides I've seen on the internet, I chose to raise the plant above the level of the hole. I suppose you could skip it. If you don't want to raise the plant from the hole like I did, skip this step. Glue a 2" length of 1" diameter PVC pipe to the inside of the plant hole so the entire length of PVC is on the inside of the bucket. Use lots of glue so it's sturdy and seal it well. (fig. 3b)
- Screw the threaded end of the 3/8" ID quick-connect male connector into the wick hole from the outside of the planter so the quick-connect end is on the outside. (fig. 3c)
- Seal this connection with hot glue or some kind of sealant.
- Get half of the wick into the 6" length of 3/8" ID hose (fig. 3d) and connect it to the outside of the planter, threading the other half of the wick into the planter through the wick hole. (fig. 3e)
- Attach the quick-connect tee connector to the end of the hose, so the connector looks like an upside-down letter "T." For the last planter, substitute the tee connector with the quick-connect elbow.
- Put a bunch of 1/4" diameter holes in the 12" length of 1-1/4" diameter PVC pipe. I used my soldering iron.
- Put a 1/2" diameter hole in the end cap
- Cover this hole with a small piece of mesh. Glue it in place on the inside of the end cap. This will help keep away the mosquitoes if the planter has standing water inside. Set this aside until you are ready to insert the plant..
comments
Add Comment
velvel (author)
says:
Add Comment
