3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Upside-down glasses
Upside-down glasses
Here's a quick simple pattern for making glasses that turn your vision upside down. Although this could be cut by hand, it'd be nearly impossible. All of this was designed for the Instructables laser cutter. The only things you need for materials are 4-40 machine screws, standard washers, and 4-40 nuts, four of each. You'll also need a piece of mirrored plexiglass.
Step 1Download and laserize
If you just want to get yourself a pair of perspective flipping goggles, all you have to do is download the file, arrange the parts to be cut (being sure to include two earpieces, they're identical, you know) and laser cut yourself a pair (mirror side down on the plastic, please.) It's pretty simple.
What those of you without laser cutters (poor souls that you are) may take away is this cool construction method I learned from puzzle maker Lee Krasnow. I measured my screws, nuts, and washers, and modeled them simply in cad. I measured the width of my plexiglass. Knowing those dimensions, I could make some tabs in the design. When the design is put together, the tabs keep the different panels aligned and square to one another. the screws fit down through the holes, and connect with the nuts in the adjacent panel. The nuts are held fixed by their tight fitting in the plastic. Putting these together is a breeze, really.
25 comments
Sep 24, 2011. 7:45 PMAdum24 says:
Woah, the glassses are, like, upside down or something! ;) (JK LOL)
Jun 12, 2011. 6:29 PMpatriots8888 says:
(: İsİe‡
_o İuo ‡uP 1 ¡ßooT
Jun 13, 2011. 4:27 PMpatriots8888 says:
woah what happened to my coment….
Jun 11, 2011. 7:13 PMCyberscann54 says:
found the real deal for $30 at http://sciencekit.com/
Jun 10, 2011. 7:49 PMCr4zy_Dud3_0n_F1r3 says:
Cool, saw something like this on Bones today, fascinating.
Oct 11, 2009. 5:08 PMspecopps117 says:
What is the point of removing vids?
it ticks me off...
Feb 24, 2008. 10:38 PMold_bass_masta says:
wear them constantly for 3 days and your vision will correct it by flippin it over
Apr 6, 2008. 2:58 AMduck-lemon says:
ok i made and have been wearing for three days (much to my teachers delight) and my vision has not flipped over. you are a LIAR! LOL
Apr 26, 2009. 4:14 AMMeie says:
yeah, i did it too :p and it didn't flip over as well :(
Apr 13, 2008. 8:12 AMold_bass_masta says:
heh, maybe you are just weird! jks jks man. My dad told me that one. and some people's vision flipped
Sep 7, 2008. 4:01 PMbujo0 says:
ya, if you were them constantly, like never take them off, for long enough your mind will flip the image in your head and you'll see normal. then when you take them off, everything will be upside down until your brain resets it. they did this as a psych experiment once. i wish i had a laser cutter to make a pair and try it myself
Sep 7, 2008. 4:49 PMold_bass_masta says:
if iwanted them id use my uncle's plasma cutter. i love it!
Apr 23, 2009. 5:21 PMMeie says:
check my painting i made with the glasses:
http://www.youtube.com/watch?v=XdXgoLezKnc
(btw, after some research, i found out its waaaay better to use some prisms from binoculars, much more sight and you don;t have to look down)
Dec 18, 2007. 8:19 PMT3h_Muffinator says:
Haha! Cool! Awesome attempt, Eric! You were so close! I'm just curious - where does one go to get acrylic sheets/ mirrored acrylic sheets? (Other than the Instructables Supply Shelf....)
Jan 27, 2008. 10:37 PMprank says:
usplastics.com it's called reflective acrylic or mirror-backed acrylic. Something like that.
Dec 18, 2007. 6:22 PMnagutron says:
i think someone with a steady hand could cut these out with a small saw. You don't need all the tabs and grooves; they could just glue them together with the right angles. You might also try uploading the design to Ponoko; then people can just order them directly, from there...
Jan 15, 2008. 4:56 AMBubjo says:
I cannot open the pdf file with instructions. I see you did it. Can you email me the instructions as attachement? Thanks in advance. Bub bub@buroojongerius.nl
Dec 29, 2007. 6:42 PMzachninme says:
Cool! Although, I think your french needs a bit of work, n'est-ce pas? ;-) Have you tried wearing them for extended periods? That sounds fun...
Dec 19, 2007. 9:15 PMryanzxc says:
Good instructable. It reminds me of a pseudo scope. it inverts the image so the right eye sees what the left eyes sees and vise versa. It severely messes with you depth perception. Both are cool demonstrations of the brain's interpretation of vision.
Dec 19, 2007. 1:19 PMrickharris says:
better still wear them for a while - Psychological experiments show that after a while your brain does an invert of the image so you see properly. When you take them off for a while your vision is inverted until your brain re converts to normal - thus showing that vision takes place in the brain not the eye.
Dec 18, 2007. 7:08 PMGorillazMiko says:
lol, cool and funny looking! haha
Dec 18, 2007. 6:17 PMPatrik says:
Heh - pretty goofy. :-D You could also get the same effect with a set of (heavy) lenses. If you want to maintain the proper line of vision, you can rig up a similar set of glasses with three reflections, using a mirrored V suspended above a horizontal mirror. If you want to switch left-right instead of top-bottom (i.e. view the world in mirror image), you could rotate the entire light path for each eye, such that the mirrored V is now oriented vertically. You could also switch the left and right eye. As you've discovered, most of these designs will only allow a fairly narrow field of vision, and/or get very bulky. For a wider field of vision and even greater flexibility in visual distortions, get a set of VR glasses and 2 webcams...
Dec 18, 2007. 6:13 PMac1D says:
Look cool! Can you add a video of the result ?
Dec 18, 2007. 6:12 PMBrennn10 says:
Wow, these are great! Nice job!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
111
Author:bofthem(HAR.MS)
I'm M@. If you know Prototype This, TechShop, The Best of Instructables, Show Me How, or AVPII: Requiem, you've seen some of my work and the cool stuff I've been involved in. I build and design and ma...
more »
