Urban Prospecting Detector
The project, called the Urban Prospector, is basically a modified metal detector outfitted with a combustible gas sensor that can be built for under 100 dollars. By scanning the surface of your neighborhood, you will be able to determine pockets of oil and other toxins.
Until recently, oil prospecting has been a field left to the professionals because it requires sophisticated tools for detection. But in much the same way gold prospecting empowered people to find small nuggets of profit, urban prospectors now have the potential to find small nuggets of oil near oil spills, abandoned gas stations, and industrial sites. Given the current high cost of oil, these urban spills or potential gold mines are waiting to be tapped.*-
Go to UrbanProspecting.net for more info.
[Video(http://vimeo.com/4563727, {width:425, height:350})]
Step 1Compile Materials
Compile Materials
For this project you will need:
-TIF 8800 combustible gas detector http://www.tequipment.net/TIFTIF8800.asp
-Used metal detector (this can be ordered from ebay.com)
-Soldering iron and solder
-2 colors of 24 gauge wire
-electronics screwdriver kit
-hot glue gun
-wire cutters
-vice and pliers
-Dremel rotary tool
Using a used metal detector found at on ebay, one can remove the metal sensor and replace it with a combustible gas sensor. So, to get started on your own Urban Prospecting Detector you will first need to compile the materials and equipment specified in the list above.
33 comments
May 14, 2009. 6:52 AMhaz says:
Great idea. I was thinking that a combustible sensor must be calibrated before use. Without a known concentration of gas being applied to the sensor the unit will not be accurate and will give wonky/false readings. How do you do your bump test or calibration? Would you use a 50% methane or a pentane equivalent? Haz gvince4
Dec 12, 2010. 8:38 PMAdam Outlaw says:
Hey haz, I would guess a caveman simple way to calibrate or tune that device might be to build a test air chamber out of a fully enclosed glass fish tank,etc. Then try putting various amounts/types of oil,etc in the controlled environment tank till you reach some useful & usable data. Hope this helps:)
Dec 12, 2010. 8:12 PMAdam Outlaw says:
Every problem ( finding its practical financial use) = a solution... (try going into business as an affordable property oil contamination inspector) = profits$$$
Aug 3, 2010. 9:47 PMA good name says:
How exactly are you making money off of this? It isn't economically viable to build a pump every time you find a small spill, and I'd assume the oil would degrade quite a bit after being left out in the open so long.
May 6, 2009. 11:50 PMrandofo says:
You must be laughing all the way to the bank doing this in Greenpoint. You should add something to your Instructable about why Greenpoint is such a wonderful place to prospect (unless... of course... you are trying to keep the competition away). This project is the best thing I've seen all week.
Jul 9, 2009. 8:16 PMscafool says:
I liked the instructable after I read it. I liked it even more after I read Wikipedia about the Greenpoint oil spill lawsuits. Haz has a good point about the calibration of your sensor
May 8, 2009. 7:38 PMDoveman says:
How do you get it out of the ground? =I
May 30, 2009. 4:15 PMGage987 says:
dig as in with a shovel,excavaitor,and/or mexicans paid with beer JUST KIDDING NOT RACIST DON"T CALL THE FCC
May 30, 2009. 4:13 PMGage987 says:
you could dig up the dirt and put vast amounts of pressure on it to get the oil and use/sell it
May 8, 2009. 12:39 PMfly_boy_bc says:
How exactly am I supposed to make any "untold riches" of of oily dirt?
May 10, 2009. 9:34 PMToulouse says:
1) get this detector 2) detect oily dirt 3) ?????? 4) PROFIT
May 14, 2009. 4:22 PMtobybirch007 says:
This post reminded me of "The Underpants Gnomes" from southpark...
May 20, 2009. 5:00 PMlogman234 says:
Same here!
May 8, 2009. 2:54 PMCryptonat says:
This is a proof of concept.
May 8, 2009. 3:52 PMfly_boy_bc says:
It proves what exactly? That the author thinks you can make money on something that needs to be cleaned up at great cost?
May 14, 2009. 8:52 AMjdkchem says:
It proves P.T. Barnum was a genius.
May 14, 2009. 5:13 PMfly_boy_bc says:
A yes PT Barnum. "This way to the fabulous egress" was his standard "exit" sign.
May 8, 2009. 3:51 PMfly_boy_bc says:
"Given the current high cost of oil, these urban spills or potential gold mines are waiting to be tapped." No they are NOT theare waiting to be cleaned up at great cost!
May 11, 2009. 8:55 AMCryptonat says:
Proof of concept: He created an 'afforable' detector that the layman can make. It doesn't have to be some sort of UBER DETECTOR MAJIGGER. "Given the current high cost of oil, these urban spills or potential gold mines are waiting to be tapped." Whats the matter of having a little fun with the instructable?
May 19, 2009. 6:54 PMleepinlarr says:
hey it works !!!, look, he found a refinery
May 11, 2009. 10:34 AMradiochemist says:
so where exactly do you go to sell the crude oil you find once you manage to somehow extract it?
May 14, 2009. 8:45 AMjdkchem says:
Ebay! ;)
May 14, 2009. 4:59 PMradiochemist says:
lol oh ok, in that case I'll sell my jersey oil 30 bucks a barrel below the saudis and make my own version of dubai on the jersey shore! thanks meg whitman!
May 14, 2009. 9:01 AMThelemic_Potter says:
I'm rather shocked that people here can't think of any uses for a device that detects environmental pollutants. Seems like a perfect addition to workshop cleanup equipment or for checking urban areas before gardening, hell a good way to keep tabs on local trouble spots, perfect for the environmentalist. great work here
May 14, 2009. 8:55 AMcamscam says:
since everything about this instructable keeps saying "hipster this and hipster that" and everyone reading the project is thinking, "would this actually do anything for me? An oil-spill detector?" I'm sorry my friends, it's of no use. These "hipsters" only care about "irony."
May 14, 2009. 8:51 AMjdkchem says:
So you hack a metal detector by adding a combustible gas sensor and magically you're going to find oil, in Greenpoint of all places. More likely your going to find nothing more than the spot where someone has been dumping used oil or a leak in a natural gas line. Then there's the water treatment facility nearby.
May 9, 2009. 6:36 PMwenpherd says:
have you faund anything? if not then how do you know it works?
May 9, 2009. 4:54 AMlil jon168 says:
they cost $179.00
May 8, 2009. 8:28 AMCartermarquis says:
Congrats on being featured on Gizmodo! Gizmodo.com
May 7, 2009. 6:22 PMamaze says:
Omg I live in greenpoint too but its starting to smell there
May 7, 2009. 11:05 AMunseen wombat says:
Oh neat! Untold riches! I'll just build me one of these and go prospecting for some dirty oil that some guy spilled while doing an oil change, then take it home to my REFINERY that I conveniently built one afternoon in my back yard and never pay for gas again! Untold riches!
May 7, 2009. 8:47 AMzwheel says:
Then what? Do you have a method of extracting the oil? Or is there a company which would pay you for the information about where to go extract it themselves?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
31
Author:splnlss(joncohrs)
I teach, work on art projects, and master music. For more info on me go to http://joncohrs.com or for more projects go to http://splnlss.com for audio go to http://spleenlessmastering.com thx!! Feel f...
more »
