Urban Traveler Survival Tin
Introduction: Urban Traveler Survival Tin
I've been looking for an instructable for a Travelers Kit, all I found were instructables on "Wilderness Survival Tins". Well not all of us goes to the wilderness like me, I travel a lot for business. So I put together an "Urban Traveler Survival Tin" of some of the most common stuff that I might use when I'm out of town, small stuff that are really simple but when you are faced with a situation that you kinda need something and you don't have that small "thing" it's reall irritating. So I put together my first instructable.
Hope it helps fellow urban travelers out there.
My Urban Traveler's Survival Tin is basically
1. the Swiss+Tech Tin came with my Utilikey
2. T1 Business Card by Tool Logic
3. A Paracord Bracelet, made from 9 feet 550 Paracord
4. A Paracord Keychain made from 3 feet 550 Paracord
5. A waterproof Solitaire Flashlight by Maglight
6. A 8-in-1 Utilikey by Swiss-Tech
7. A pair of Nail Clippers
Step 1: Inside the Tin
Inside the Swiss+Tech Tin (I just removed the foam inside) are the following:
1. Paracetamol for fevers
2. Ibuprofen for pain relief
3. Amoxicillin for pain relief
4. Carbocisteine for cough (I already used them)
I cut the foil really close to the capsule to save space
5. Bandage Strips (used to be 5 of them)
6. Bottle of Betadine (Iodine for wounds)
7. Zipties (great for locking you luggage in airports, instead of using padlocks)
8. Large Safety Pins (great for repairing large tears in jeans or bags)
9. Cuetips (I heat-sealed them in plastic to keep them clean)
10. Loose cotton (also heat-sealed in plastic)
11. A small sewing kit I swiped from one of the hotels I stayed in
12. Microporous Tape
13. 2 x 2 Gauze Bandages (not here, used them for a buddy who tore his arm in the airport)
I taped two razor blades for precision cutting, on the inside of the cover tin
I also added a small Silica Gel packet to keep moisture out (you can get them from old medicine bottles or sometimes inside new shoes that you buy)
Step 2: The Paracord Bracelet and Keychain
The Paracord Bracelet and the Key Chain (you can find a lot on instructables on making your own so I'll not go into that) means that I can carry about 13 feet of paracord everywhere I go, great if one of the boxes I have in the airport breaks open, I can tie it up using the cord (this actually happened to me once, after I got home, I just retied the bracelet)
The Utilikey is great when you're out for beers, my eyeglasses pop loose, you need to pry open something.
The Solitaire is great when there are blackouts in the hotel (happened to me once or twice already)
The Nail Clippers are there for obvious reasons, hangnails, forgot to cut your nails, need to nip something, etc...
Step 3: The T1 Business Card
This is a great tool from Tool Logic, I actually keep it in my wallet (which is what it was designed for), in an instant I can whip out:
1. Precision Philips Screwdriver
2. Precision Flathead Screwdriver
3. Tweezers
4. Toothpick
5. Sewing Needle
6. Ballpoint Pen (refillable)
7. Nail File and cuticle tool
8. Small Razor Knife
9. Small Scissors
10. There's also a cm and inch ruler on both sides
    • Paper Contest 2018
      Paper Contest 2018
    • Pocket-Sized Contest
    • Science of Cooking
      Science of Cooking
    There are two things that I would add (there in all of my survival kits). 1-Duct tape the good kind not the cheap kind and 2- fishing line. Yes, fishing line. Its great because you could use it to tie things together, and you could tie it to two ends of a biulding and put a tarp over it to make a make ship tent. Also there could be a deep puddle and you could fish. Hahaha.
    Anyone know a cheap alternative/ item similar to the Utilikey? Something like that could be very useful, but 10 quid is a bit much for it.
    Lifehacker suggests handy people could build one out of an old key... http://lifehacker.com/5901312/turn-a-key-into-a-10+in+1-tool
    Amoxicillin isn't a painkiller, it's an antibiotic. Use responsibly to prevent bacteria becoming resistant to antibioics. Pack soluble aspirin then use it dissolved in water as a painkiller for sore throats or mild toothache. Pack Imodium or Loperamide for diarrhoea.
    Thanks for pointing this out, if you hadn't I was going to.
    I'll add that using it responsibly means getting a prescription for a specific infection, and FINISHING THE ENTIRE PRESCRIPTION. To fail to do so is to risk breeding antibiotic resistant microbes, and we all know we have enough of those in the world.
    Thanks, i'll update my kit with your tips :D
    If you don't have enough Amoxicillin for a full course of treatment, don't bring it at all. There is a huge risk of creating more disease-resistant bugs otherwise. If you must bring something "quick-and-dirty" as an antibiotic, ask your primary-care physician for a script. They won't mind, and you might help stave off a global pandemic of yet-to-be-known disease resistant bugs.
    Great idea. I wouldn't recommend using a maglite for the flashlight, however. You can buy some LED lights that are actually smaller and brighter now...
    Other than that I like what you have included in the kit!
    Go for a small light that doesn't run on batteries; solar or hand crank. All you have to do is pull it out of your pocket anywhere with lighting and it'll charge. Hand crank lights are a little more bulky, but you don't need to rely on ambient light to keep your flashlight going.
