Urethane Resin Casting a Joby Gorilla Pod Hotshoe Camera Mount - Reaction Injection Molding (RIM) Part:2
28,193
438
14
Published
Introduction: Urethane Resin Casting a Joby Gorilla Pod Hotshoe Camera Mount - Reaction Injection Molding (RIM) Part:2
About: Eric Strebel, Industrial Designer of Botzen Design, designs products for industry around the world.
This is Part Two: how to Injection Cast Urethane low volume high quality plastic parts in a Silicone mold. Sometimes also referred to as Reaction Injection Molding (RIM), the process allows you to meet your low volume, injection molded plastic part needs with out aluminum or steel tooling. In my case I just need a few high quality parts, but they need to be as strong or stronger than an injection molded part.
In Part ONE of the Instructables I cover how to make the Silicone Mold that we will be injecting the Urethane resin into to make the plastic parts. Check it out here.
You will need the following for this project.
-Silicone Mold
-Two part resin, I recommend a Quality Urethane from Innovative Polymers I will be using IE-3076
-Digital cooking scale for accurate mixing of the resin
-Protective gloves to keep your body from getting sticky and absorbing harmful materials
-Mixing Cup
-Mixing stick
-Colorant, a pigment of some sort to make your parts a specific color
-Wax paper or Aluminum foil to keep resin off your work surface
-Kitchen Timer so you know how long you have to work your resin
-An good place to work
-60ml syringe
Optional: Vacuum Tank/Chamber and a pressure tank for bubble free parts
Step 1: Mixing Your Urethane Resin
There are many types of resin out there with all kinds of hardness (shore) properties. This is great if you need a flexible part for something like a mobile phone case, or if you need a super strong part like I am making.
I am mixing up about 60grams of Innovative Polymers IE-3076 see video
I set out my digital kitchen scale set to grams (metric is way more accurate don't waste your time with oz.)
I tear the scale with the dollar store cup on it to zero and add the Resin (yellow tinted), about 30g. Make sure you mix according to your manufactures specifications. At this point you would add a colorant to tint your resin. There are many kinds out there as well, most resin suppliers will sell tints as well. As long as it's not water based you should be good (water moisture will cause the resin to bubble and you will have lots of air bubbles in your part)
Next mix the Hardener according to the specified weight ratio for your product and start your timer. I know that this resin has about a 14 minute working (pot) time. It allows me a lot of time to mix and De-gas the resin and get into the mold.
Mix your resin really well, scrape the sides of the cup numerous times and get down into the bottom edges of your cup. Notice how I am using a squared off mixing stick and not a rounded one like a tongue depressor, see video for more details
Step 2: De-Gas Your Resin in a Vacumm Chamber If You Have One
Once the resin is thoroughly mixed we quickly place it in the vacuum tank, see video
I use a three gallon top load tank with a 4CFM vacuum pump. If you don't have a Vacuum tank you can still make the parts, but they my have air bubbles in them. Some resins are also a bit less susceptible to air bubbles from mixing. I would suggest one of those if you don't have a tank to De-gas your material.
You can see the bubbles being pulled out of the resin in the video. Once you have a full 30hg of vacuum and the bubble stop then you know you have gotten all the air out of the resin and you can use it to cast your parts. With this resin I usually have about 5-6 minutes still left in my 14 minute working time to actually get the resin into the silicone mold.
Next: getting the resin into the mold!
Step 3: Getting the Resin Into Your Silicone Mold
Injection time: Now we need to get the resin into two part Silicone mold. In the video I begin by pouring the resin into the mold. I show this because it does not work well. You will need to inject the resin into the mold with a syringe. You will need a syringe that has the capacity of the cavity of your mold. You may need a bigger or smaller syringe than I have, depending on the size of your part you are making.
Plunge the stopper of the syringe to the bottom, and place it in your De-gassed cup of resin and draw the syrup into the syringe making sure to always keep the tip in the fluid so that you don't introduce any air into the resin.
Once you have enough resin in the syringe, inject it into your mold slowly as you wait for it to level, and come out of the vent hole.
Once it's filled with resin you are done. If you have a pressure tank then you can go to the next step.
Step 4: Add Some Pressure and Some Time to Get Good Parts
If you don't have a Pressure tank you can still make parts. The tank however will allow you to cast parts that are bubble free. I use the one in the video for most of the casting work that I do. Theoretically the parts should be bubble free since we already evacuated all the air out of the resin, but this is the real world and our system is not closed so there does exist the possibility of air having entered the system. (plus urethane react with the moisture in the air to expand to create air bubbles) So just in case we did not remove all the air in the de-gasing process we will attempt to crush whatever air is in the resin down to a microscopic level by placing the mold with the resin into the tank under about 60 PSI of pressure.
I am using a converted paint pressure tank tank as a pressure pot for my casting. They are readily available on eBay.
Let the resin set up under pressure. Once it's set you are finished and ready to de-mold your part form the silicone mold.
Step 5: Demold and Clean Up, You Are Done!
Let the air slowly out of the tank and remove the silicone mold and the part. I am very gentle in the video as the part has cast threads and I don't want to rip the silicone and ruin the tool! Take your time. You should get a great part if you followed all the steps. If may take you a few times to get a perfect part. It's totally achievable with some practice and patience. There should be very little clean up, if you made a good silicone mold. Just trim the Sprue and Runner at the gate and you should be done.
I hope you enjoyed this tutorial, follow me and share with your friends that may like this, subscribe to my videos on Youtube so you are alerted when I release new ones.
Leave your comments below and let me know how your project turns out.
About Me: I am an Industrial Designer living in Southfield MI USA. I have a home-based Product Design Studio called “Botzen Design”and have been designing consumer products for 25+ years ranging from sunglasses for Bauch & Lomb, Traps eyewear, entry level luxury vehicles for Ford, wireless charging PowerMat for Homedics, to magnetic toys for Guidecraft. I specializes in tabletop and handheld products, ranging from WiFi routers to cosmetic products to Bluetooth devices and everything in between, I also teach Industrial Design at Wayne State University and CCS (College for Creative Studies) Follow me on Twitter @botzendesign and Subscribe to my Youtube channel Here.
$5.99 plus shipping per cold shoe, just send me a PM
If you need a consumer product designed or high quality Urethane parts made feel free to contact me through my website.
You can check out Part one to this and my previous Instructable here about how to make your own Home made silent shop compressor from a refrigerator motor, and a glow in the dark vehicle antenna.
You can purchase a cast Urethane Joby Hotshoe adapter Here.
    • Make it Move Contest
    • Oil Contest
      Oil Contest
    • Casting Contest
      Casting Contest
    14 Comments
    What wattage / diameter hot plate do you use to add heat to the cure process
    Not sure, it was a vintage coffee pot warmer, just get one that is adjustable so you can vary the temp.
    Hi I was just wondering what size air tank you use to pressurize your pressure tank for crushing bubbles while the resin cures. Do you use the modified 6 gal tank in your other instructable that you put a fridge compressor on? Or do you use one with a larger tank? If I did the math right a 6 gal would have to turn on multiple times while you are pressurizing the tank to 60 psi. Is this what you experience?
    You wrote and excellent Instructable! Thanks for sharing your knowledge.
    Great instructables, thank you for not sending us straight to video or youtube.
    I like your setup! Especially your little autoclave.
    Thanks, its a pretty handy unit to have in the shop for mold making. You can see a bit more on my website www.botzen.com
    Always looking for Urethane casting work.
    Thanks for sharing your knowledge here! I haven't got around to making an Instructable about it yet but as I'm sure you can imagine, a lot of your skills you demonstrated here can be applied to making false teeth. I used cold cure acrylic resins I got from dental supply manufacturers at a fraction of the $2000 my dentist wanted
    Hi there,
    I'm wondering where you get the IE-3076 do you buy it direct... or from a distributor? not seeing it on Amazon, or even their website... thanks
    simply amazing any info on making a mold so I can create a polymer resin part?
    Yes I agree . many books on it but handy to have a reference here. Good stuff
