3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Urethane Rubber Molds
video Urethane Rubber Molds
Urethane Rubber molds are widely used when a flexible mold material is required and a more expensive or less abrasion-resistant silicone rubber is not desired. However, their use requires careful application of release agents.
To see other mold making videos see http://www.freemansupply.com/moldmaking.htm
7 comments
Dec 27, 2007. 4:58 AMsnoyes says:
I wonder if I could pull 29 inches of mercury with a shop vac and a 5 gallon bucket...
Apr 23, 2011. 9:08 PMdreadengineer says:
Real vacuum pumps are actually pretty cheap on Ebay; I've seen them for under $75.
Nov 24, 2008. 6:59 PMn0ukf says:
I seriously doubt it, no matter what brand or model you get. You need a vacuum pump to get that high. Vacuum cleaners are made for high volume suction, not high intensity. Just like the foot bellows pump for pool toys won't inflate your car tires, high volume vs high pressure.
Dec 28, 2007. 1:47 AMsmokehill says:
With a big enough Shop-Vac, it might work. I have a big one, but don't have a spare vacuum gauge to test it. Most cars (at least what I consider a real car, e.g. an old V-8 Ford van), will pull about 19-23 inches of mercury. To make work vans for one of my businesses, I tap into the brake booster line and use it to pull steady vacuum on a 300-gallon tank thru standard 3/8" fuel line (other thin junk will collapse). It's enough to suck about fifteen gallons of sewage from a portable toilet in less than 5 seconds. It's enough vacuum that it'll eventually break the welds on a 7-gauge steel tank unless you beef up the ends with quarter-inch steel plate welded onto it. It's also enough to deform, inwards, a steel 55-gallon drum. Hard to believe, from that miniscule amount of "suck" we feel from the end of an auto vacuum line, but it's far more powerful than I ever imagined. Some shop air compressors can also be fiddled with a bit to act as a vacuum pump. I think there is an instructable to that effect ... I know I've read it somewhere. I believe it's especially easy with those cheap little Chinese & Korean 12v auto tire fillers, though it'd take a while to suck any AMOUNT of vacuum (as opposed to just the inches of merc. One thing I've learned about vacuum is that sometimes just the sheer AMOUNT of it is more important than the strength of the "suck."
May 2, 2008. 1:59 PMgwrober says:
Excellent vid!
Dec 26, 2007. 1:47 PMGorillazMiko says:
oh yeah... cool video :-)
wow... you sure are posting a lot of stuff.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
61
Author:freemanmfg
