Step 1Materials and Instructions
Materials:
2 Ethernet Hubs (8pin RJ45 - salvaged from network cards)
1 Usb Male Plug Type A (any standard Usb cable)
1 Usb Female Plug Type A (from a Pc)
Solder Gun, wire and electric tape.
and of course a CAT5 Ethernet Cable
Instructions:
The hardest part was desoldering the Hubs from the salvaged PCB board, after that it was just a matter of selecting which cables of the CAT5 use to solder the Usb plugs and the RJ45 Hubs.
I select the pins in the following order:
RJ45 hub = USB plug
pin No. 2 = Green Cable
pin No. 4 = White Cable
pin No. 6 = Black Cable-Ground
pin No. 8 = Red Cable
I test the configuration at the other end and test the web cam (my work very well) later I isolate each soldered connection with electric tape (with yellow tape) and cover the hole thing (black tape), and voila!. 25' of video cable (plus the hubs) and working.
Easy and extremely cheap.
1. On the RJ-45 8-pin jack, you want to avoid pins 1,2,3,6 because if it accidentally gets plugged into a switch or PC Ethernet jack, the 5-volts could fry something.
2. You want the power (+5v,ground) on the same color (blue,blue-stripe) so it doesn't make an electronic field that can ruin the valuable data lines. the phone company runs 24V to our homes on one twisted pair of wires and it works fine.
3. Twisting the two data lines on one color (brown,brown-stripe) will keep data integrity over a longer run of lines. Ethernet lines do that and it works just fine.
I suggest the following from the USB to the Cat-5 jack:
1. usb pin 1 (+5v,red) goes to RJ-45 pin 5 (blue-stripe)
2. usb pin 2 (d-,white) goes to RJ-45 pin 8 (brown)
3. usb pin 3 (d+,green) goes to RJ-45 pin 7 (brown-stripe)
4. usb pin 4 (ground,black) goes to RJ-45 pin 4 (blue)
Using this configuration, you could simultaneously run Ethernet to a hub AND your USB extension with splitters and all.
these are my observations:
usb power supply pins1 and 4 can supply with a steady 5 volts on both cat5 cables. cable 1 below 5 meters and cable 2 above 5 meters both registered on the tester 5 volts steadily.
while testing on terminal +data and -data i get a drop of .5 when i put the testers over 1x continuity.
this lead to a conclusion that signal from the usb running through a cat5 cable drops after 5m. but the 5v supply from the usb running through a cat5 is a steady power supply.
i made this project because i want to use my socket A old cpu as surveilance system of our home using usb webcams. i can connect up to 4 webcams but distributing it around the house is very tricky. im avoiding also of ip cams because of it's high costs any suggestions on how i might solve my problem? thanks for your ideas.
