Usb to Serial/TTL Adapter
135,243
48
16
Posted
Introduction: Usb to Serial/TTL Adapter
hello guys this is my first post so bear with me. I order a usb to serial adaptor  for $1.78 from ebay and wanted to try and make it work. since there is no information from the seller exept that is based on the PL2303. Since we have no info and no drivers I decided to google and I found a driver that might work  it comes from prolific  http://www.prolific.com.tw/UserFiles/files/PL2303_Prolific_DriverInstaller_v1_8_0.zip.
Step 1: Drivers Installation
we download the driver and we unzip the files. then we run the driver installation program. I am not going to post pictures and step by step instructions because all you have to do is click "ok" and "install".
Step 2: Connecting the Adapter
now that the software is done installing just hit "Finish" and connect the adapter to you computers usb port. the hardware wizard pops up and it automaticly installs the driver for you. We can check our installation by going  in to the device manager and  ports.
Step 3: Verify the Installation
we now have to verify the installation, we see in the device manager that it has installed right and the it is set  as COM5. the driver comes with a  utility that verifies the  chip version just go to the driver folder that was unzip earlier and run checkchipversion.exe  we set it to COM5 and we click on "check" it will give you the chip you have since there are a lot of versions of the PL2303.
Step 4: Testing Our Adapter
we can test our adapter using the arduino IDE. we change the port to COM5 and we put a jumper on the adapters pin TXD and RXD.
Step 5: "Hello World"
We open the the serial monitor and we type "hello world"....and we are done.. that's all folks.  I am working on some projects to test the capabilities of the PL2303 will post the later. that's all for today and this was my first instructable ever so bear with me.
    • Microcontroller Contest
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    i have this same usb serial but i want to connect it with fpga board having jtag on it .Im confusing in that TXD and RXD where to connect on that jtag header having 10 pins (TDI, TDO, TCK ,TMO)
    14 Comments
    I can't install it on Windows 10
    I also had this issue with Windows 10. Worked fine under Windows 7. I found this "older" driver that works with Windows 10 and I am using the adapter again!
    http://www.ifamilysoftware.com/news37.html
    it works nice in w10x64. thank you.
    I have a question. I have installed windows 10 and I can't seem to make it work.Allthough the drivers are installed and the pc shows in device manager the usb and the COM it says that it is not possible to start the device.Furthermore in the program that was included in the drivers I downloaded when I try to check my Usb in the correct COM it says "OPEN COM PORT FAILED" . What shoud I do? Thanks in advance
    Hi Verdelj, Can I ask which programmer you have selected in the Tools>Programmer?
    Thank you so much. :D
    I have same adapter, before I tried with many prolific drivers but did not work. With your zip file worked. Finally I can use my TTL adapter. Thank you.
    Hi! When connected as you mentionned i cannot access tools menu from arduino
    thank you!
    marC:)
    Try to create a new sketch and see if it works.
