Introduction: Use 8x8x8 RGB LED Cube on PcDuino
Picture of Use 8x8x8 RGB LED Cube on PcDuino
8x8x8 RGB LED cube is one of the stunning RGB LED Cube designed  by LinkSprite. It has Arduino compatible interface and uses the SPI interface to communicate with Arduino/pcDuino.
Step 1: Wiring Diagram
Picture of Wiring Diagram
The 8x8x8 LED Cube can be directly installed on pcDuino. However, we do recommend to use a T Board to translate the voltage.
Step 2: Test Code
#include <SPI.h>
#define STATUS_PIN 9
#define CS_PIN 10
#define MOSI_PIN 12
#define MISO_PIN 11
#define SCK_PIN 13
#define SPI_MODE SPI_MODE1
#ifdef PCDUINO_IDE
   #define SpiExchangeByte(x) SPI.transfer(x,SPI_CONTINUE)
#else
  #define SpiExchangeByte(x) SPI.transfer(x)
#endif
void SetDefaultTask(char task,long repeatTime)
  bool DeviceStatus;
  unsigned short count;
  DeviceStatus = digitalRead(STATUS_PIN);
  digitalWrite(CS_PIN,LOW);
   SpiExchangeByte(2);
   while(digitalRead(STATUS_PIN) == DeviceStatus);
   DeviceStatus = !DeviceStatus;
   SpiExchangeByte(task);//X
   SpiExchangeByte(0);//Y
   SpiExchangeByte(0);//Z
   SpiExchangeByte(repeatTime & 0xff);//R
   SpiExchangeByte((repeatTime>>8) & 0xff);//G
   SpiExchangeByte((repeatTime>>16) & 0xff);//B
   SpiExchangeByte((repeatTime>>24) & 0xff);//RSV
   digitalWrite(CS_PIN,HIGH);
void SetLedCubeColor(long color)
  bool DeviceStatus;
   SpiExchangeByte(1);
   SpiExchangeByte(0);//X
   SpiExchangeByte(color & 0xff);//R
   SpiExchangeByte((color>>8) & 0xff);//G
   SpiExchangeByte((color>>16) & 0xff);//B
   SpiExchangeByte((color>>24) & 0xff);//RSV
void SetPonitColor(char x,char y,char z,long color)
  bool DeviceStatus;
   SpiExchangeByte(3);
   SpiExchangeByte(x);//X
   SpiExchangeByte(y);//Y
   SpiExchangeByte(z);//Z
void SendImageData(void)
  unsigned short tmpShort;
  bool DeviceStatus;
   SpiExchangeByte(4);
   SpiExchangeByte(0);//R
   SpiExchangeByte(0);//G
   SpiExchangeByte(0);//B
   SpiExchangeByte(0);//RSV
  for(tmpShort =0;tmpShort < 512*3;tmpShort ++)
    SpiExchangeByte((char)tmpShort);
void setup() {
  // put your setup code here, to run once:
  pinMode(STATUS_PIN, INPUT);
  pinMode(CS_PIN, OUTPUT);
  pinMode(MOSI_PIN, OUTPUT);
  pinMode(MISO_PIN, INPUT);
  pinMode(SCK_PIN, OUTPUT);
  digitalWrite(STATUS_PIN,HIGH);
  digitalWrite(SCK_PIN,LOW);
  SPI.begin();
  SPI.setBitOrder(MSBFIRST);
  SPI.setDataMode(SPI_MODE);
  SPI.setClockDivider(SPI_CLOCK_DIV4);
  SetDefaultTask(0,15);
  SetLedCubeColor(0x00000000);
  SendImageData();
  delay(5000);
void loop() {
  // put your main code here, to run repeatedly:
  printf("SetLedCubeColor(R);\n");
  SetLedCubeColor(0x00ff0000);
  delay(1000);
  printf("SetLedCubeColor(G);\n");
  SetLedCubeColor(0x0000ff00);
  delay(1000);
  printf("SetLedCubeColor(B);\n");
  SetLedCubeColor(0x000000ff);
  delay(1000);
  printf("SetDefaultTask(1);\n");
  SetDefaultTask(1,20);
  delay(5000);
  printf("SetDefaultTask(2);\n");
  SetDefaultTask(2,15);
  delay(5000);
  printf("SetDefaultTask(3);\n");
   SetDefaultTask(3,15);
  delay(5000);
Step 3: Description Command
Picture of Description Command
8x8x8 RGB LED cube supports  four kinds of commands. The format of the commands is below: [cmd] [x] [y] [z] [r] [g] [b] [rsv]
In the command sequence:
cmd is the command byte.
x, y, z, represents the three axis coordinate values.
r, g, b represents the three color of red, blue, green value of  corresponding coordinate , rsv is a reserved char.
Command 0×01: Set the whole LED cube into a certain color. X/Y/Z is invalid.
Command 0×02: Set a demo mode, X means demo mode X. Y and Z are invalid. t/h/b/rsv means the repeat number. There are currently three demo mode.
Command 0×03:  Set the color of a certain LED.  x, y, z is the coordinate. r, g, b is the color.
Command 0×04:  Send the data starting from (0,0,0).  x, y, z, r, g, b, rsv are invalid.  The data after the command is the data of color.
Step 4: Test Result
Picture of Test Result
8x8x8 RGB LED Cube on pcDuino is very beautiful!
Yonatan24 (author)2015-11-20
Hi, I've added your project to the "A Collection of WAAAY To Many 8X8X8 RGB LED Cubes!" Collection
This is the link If you are interested:
https://www.instructables.com/id/A-Collection-of-WA...
SuperTech-IT made it! (author)2014-08-18
If you'd like something larger with more options, visit here:
https://www.instructables.com/id/8X8X8-RGB-LED-Cube/
About This Instructable
7,402views
31favorites
License:
More by Yanny Guo:Use pcDuino as Photo Booth ControllerUse Si4703 FM Breakout Board on Arduino UnoUse SIM900 GPRS/GSM Shield on pcDuino
Add instructable to:
