Use Arduino and RS232 Shield to Interface Integrated UHF RFID Reader LSID-0702
29,423
14
8
Published
Introduction: Use Arduino and RS232 Shield to Interface Integrated UHF RFID Reader LSID-0702
Long Range UHF RFID reader (1-6M) (ISO18000-6C EPC G2) integrates the reader with the antenna. After first powered on, the reader will buzz once to indicate that it starts to work.  When there is tag approaching the reader, it will buzz to indicate that it’s sending the data. For the same tag, the read interval can be configured. After read, if the same tag is still in the read area, there will be no further indication, and no data will be sent.  If the time lapse exceeds  interval or different tags enter the reading zone, the reader will read the card and send out data.
In this tutorial, we show how to use the integrated UHF RFID reader with Arduino and RS232 Shield.
Step 1: Parts List
1.1 x Arduino UNO
2.1 x Integrated UHF reader LSID-0702
3.1 x serial DB9 cable
4.1 x Rs232 shield
5.1 x UHF RFID  tag
Step 2: Wire Diagram
Install RS232 Shield v2 on Arduino, and connect the DB9 of RS232 shield to the DB9 connector of the RFID reader, and supply power to the integrated RFID reader.
Step 3: Arduino Sample Code
#include "Arduino.h"
//#define DEBUG
SoftwareSerial mySerial (5,6);
unsigned char incomingByte;
void sendIdentifyCmd ()
  mySerial.write (0x7c);
  mySerial.write (0xff);
  mySerial.write (0x01);
  mySerial.write (0x08);
  mySerial.write (0x7d);
#ifdef DEBUG
  Serial.print (0x7c);
  Serial.print (0xff);
  Serial.print (0x01);
  Serial.print (0x08);
  Serial.print (0x7d);
  Serial.println ();
#endif
void setup ()
  Serial.begin (9600);
  mySerial.begin (9600);
  Serial.println ("begin initial Serial!\n");
void loop ()
  sendIdentifyCmd ();
  delay (2);
  while(mySerial.available () > 0)
      incomingByte=mySerial.read ();
      Serial.print (incomingByte,HEX);
      Serial.print (' ');
  Serial.println ();
  delay (1000);
Step 4: Results
After we download the above code into Arduino, we we place the RFID tag to the reader’s antenna, the reader will buzz, and Arduino will print the ID on the serial port.
If we don’t know the command, we can refer to: http://linksprite.com/wiki/index.php5?title=Long_Range_UHF_RFID_reader_%281-6_meters%29_%28ISO18000-6C_EPC_G2%29_RS232
    • Clocks Contest
      Clocks Contest
    • Planter Challenge
      Planter Challenge
    • Oil Contest
      Oil Contest
    8 Comments
    Maybe something else has to be done? I tried sending the same data and get no activity on the tx from this device.
    did anyone made it work? i am working with the same device and codes, but the output is just 0 0 0 0 0 0, there's no data recieved from the reader to arduino .
    Is it possible to read “µ-Chip” (or mu-chip) with this setup?
    Thanks,
    The same project with two different accounts and anybody was capable to make it work, looks very suspicious.
    The project looks nice and possible, but the comments...
    Hi, i buy this elements and i try do this example, and doesn't work. please help me!
    This code doesn't work at all. The wiring diagram, the worst one I have ever seen. Don't waste your money on this, believe me I tried to do this!
    hi, what is the max distance for reading?
    will it work with stiky rfid tags?
