Introduction: Use Car Vacuum, Tyre Inflater, Led Etc. at Home
Picture of Use Car Vacuum, Tyre Inflater, Led Etc. at Home
This is my first instructables so please (beer) bear with me..
Step 1: Things Required in This
Picture of Things Required in This
Things require in this..
1. Car accessory
2. 12V AC-DC adaptor
3. Wire pieces
4. Lil patience
Step 2: Hook 12V Adaptor to Car Accessory
Picture of Hook 12V Adaptor to Car Accessory
Here first you should know the polarity of the car cigarette lighter plug & 12V adaptor
Almost 99% of the car cigarette lighter plug & 12V adaptor pin's polarity is outer -ive & inner +ive (99% coz am not sure 100%)
Refer the images.
Now take two wires & connect both positve & both negatives. you can use rubber bands also to hold the wires
Now connect the adaptor to power & enjoy your car accessory at home...easy!!!
Note:- you can find 12V adaptor in your modem, router, electric shaver, trimmer etc.
MikB (author)2016-11-26
You will need quite a chunky DC adapter to do this. I've got one of those little little compressors, and a 12V/5Amp power supply which "runs" it, but it definitely starts to bog down once the pressure starts building -- due to the voltage dropping.
It runs much better on a car battery!
A 12v adapter from a modem/router/shaver will probably be killed in quite short order (most are only 800mA-2Amp). Go bigger!
DIY Hacks and How Tos (author)2016-11-19
Great life hack. Thanks for sharing with the community.
About This Instructable
249views
6favorites
License:
More by YogenderV:Use car vacuum, tyre inflater, led etc. at home
Add instructable to:
