Use Command Prompt at School
2,123
27
6
Posted
Introduction: Use Command Prompt at School
Welcome to my Instructable on how to access Command Prompt at School
This Instructable contains:
1 Old Method covered in other Instructables
1 New Method which I have created so this should be the 1st Instructable which it is in
Please be aware that this can get you into serious trouble even if you don't use it for anything dangerous. I won't be held responsible for your use of this
Step 1: Open Notepad
There are 3 possible ways of doing this.
1st way (the obvious one)
Click Start
Click All Programs
Click Accessories
Click Notepad
(In my school notepad has been removed from the start menu)
2nd way
Right click in any folder window
Hover over New
Click Text Document
A new file called "New Text Document" will appear
Double Click on the New Text Document file, this will open notepad
3rd way
In a file window, search for .txt if it finds any files double click one of them
Step 2: Old Method
This is the old method, it doesn't work at my school but it might at your's.
In notepad, type (or copy-paste) the text below
@echo off
command
command.com
pause
And save the file as whateveryouwant.bat
Then open the file It should open a black window identical to the one in the picture, if it doesn't move on to the next method
Step 3: My New Method :)
This is my new method
@echo off
cd %USERPROFILE%
echo Microsoft Windows [Version 6.1.7601]
echo Copyright (c) 2009 Microsoft Corporation. All rights reserved.
echo.
:comline
set /p com="%CD%>"
goto runcom
:runcom
call %com%
goto comline
Then open the file
    • Space Challenge
      Space Challenge
    • Microcontroller Contest
    • Spotless Contest
      Spotless Contest
    6 Comments
    That's interesting, however, be aware that accessing the PC like that might get you in hot water with the school. In some school districts that's considered "cracking" and will earn you an expulsion.
    Likewise, for those doing this in a business environment, be darned certain you understand the risks of contravening IT policy before attempt this. It could land you on unemployment.
    Some organizations (business, schools, etc.) use monitoring software and can also review system logs remotely to detect stuff like this.
    I'm not saying "Don't do this," I only want you to be aware that it could have serious consequences.
    I was going to mention this when I wrote the tutorial but I forgot, I'll add it now
    I had a co-worker fall afoul of IT policy after running a portable app (it wasn't even installed) that could talk to the internet. He was out the door in 90 minutes. It was a traumatic experience all around.
    I used to work in IT for years. Seriously, don't do this. It is easily detected.
    thanks for sharing your step by step process! :)
